Author Topic: E36 318is Turbo  (Read 5463 times)
Johie
E36 318is Turbo
« on: August 03, 2010, 02:13:02 AM »
never posted here before, but i need to talk about my frustration:D
I have build turbo engine m42
td-05 turbo(lance evolution)
custom header
forge intercooler
engine block honed 85 mm
mitsubischi evo pistons 85mm
MLS head gasket
head flowed
stock cams, overlap turned away
ARP head bolts
ARP conrod bolts
M50b25 135mm conrods
New bearings
new gaskets
crankshaft balanced
flywheel lightened and balanced
Engine was running fine until i had wrong made pistons, now i have evo 9 pistons. so 1 have had the head off 1 time.
yesterday on dyno i had 270 HP on 1 bar boost, pretty good, but on 2nd run the pressure came out of carter ventilation.
the car still standing there i dont know what to do. Pull the fuckin head and pistons AGAIN:mad:???
one time during break in, i had broken coolant hose, so engine was hot. After the fix temparature was fine, ONLY when i pulled the oil cap there was already a lot of pressure. But didnt rise when on throttle!!
during Dyno there was no detonation or what so ever. Ignition advance was very weak, not tuned yet!
What will be wrong? only piston rings? or pistons? Cilinders
I dont want to trow in a lot of money. Next year i go to college again.
i am a little frustrated so if i am not very clear i'm sorry. Give me your opinions, i need them:o
El-Kanal
E36 318is Turbo
« Reply #1 on: August 03, 2010, 03:31:55 AM »
Ithink that is normal, some of the pressure willl jsut come around the pistons into the carter, you need an oil catch tank, and some breather, where did you conect the breather hose, befor or after the turbo, on the intake?
Johie
E36 318is Turbo
« Reply #2 on: August 03, 2010, 04:42:57 AM »
no not normal, i lost power on last run, and breather on oil catch tank was smoking a lot.
on 900 rpm with vacuum i shouldt have none or little pressure with oil cap removed
i have no breather hose, just oil catch tank with filter direct on valvecover
romkasponka
E36 318is Turbo
« Reply #3 on: August 03, 2010, 07:14:13 AM »
I think problems with pistons or rings. Are pistons stock evo9 or modified? Do a leak check. If it is a broken ring you can damage cylinder wall if you run engine with this problem.
« Last Edit: August 03, 2010, 07:16:51 AM by romkasponka »
E30 318is M42
E36 318is M44
ziedas nr 1
E36 318is Turbo
« Reply #4 on: August 15, 2010, 04:46:25 PM »
johnie, leak down test.do it. and i think you find the problem. i think the weak rings,or something in this area,like a romkasponka said.
Johie
E36 318is Turbo
« Reply #5 on: August 25, 2010, 04:57:31 AM »
the piston was melted, so i replaced it
but when it was finished and engine running again, no luck.
pistonpin in engine wall, so i can throw engine block away.
work is in progress i'll be back with more pressure and new block.
last succesfull run:
http://www.youtube.com/watch?v=3yTNu6rNItc
Johie
E36 318is Turbo
« Reply #6 on: November 30, 2011, 06:23:43 AM »
GOOD news,turbo setup went into an e21 with an m42 motor with stock compression and ARP bolts and MLS gasket. running 0,6 bar boost
 i went to the dyno. 236 HP and 290 Nm torgue! how much fun is that! AFR are good now, and delayed the ignition a little.
as you can see, the chrome bumper is back, and it is standing on some steel 13 inch wheels. i also recieved my new front shock aborbers.
video
[youtube]1j9d5nEpO2s[/youtube]
Johie
E36 318is Turbo
« Reply #7 on: November 30, 2011, 06:27:45 AM »
GOOD news, setup is now in e21 with stock m42, arp bolts and mls gasket
 i went to the dyno . 236 HP and 290 Nm torgue! how much fun is that! AFR are good now, and delayed the ignition a little.
video
