Has anyone bought this flywheel?
Author Topic: Has anyone bought this flywheel?  (Read 4477 times)
Mr. Drop Top
« on: July 31, 2010, 02:03:18 PM »
I heard that a good improvement on acceleration would be to get an aluminum flywheel. Has anyone bought this one?
http://thmotorsports.com/fidanza/fidanza_flywheel_aluminum/195321/i-165588.aspx?googlebase=195321-07-1994
Or is there another one I should look at?
My car is 95 auto
El-Kanal
« Reply #1 on: July 31, 2010, 02:58:14 PM »
Automatic transmissions have special flywheels and from whot i thin kthey're pretty light, if you want to improve handling of your car, conver to manual IMO
Mr. Drop Top
« Reply #2 on: July 31, 2010, 07:18:01 PM »
i heard thats upwards of 2k-3k? I think ill live with the auto :(
« Reply #3 on: July 31, 2010, 09:53:59 PM »
I bought a full swap kit for my 325 for $120...tranny, used clutch, pedals, master & slave cyl, subframe, tranny mounts, shifter rod, etc...  I'd put in a new clutch kit (~$250), a short-throw Z3 shifter (~$100) and replace all the rubber & plastic bits.  Doing your own work with a bit of scrounging could make it even less than the $500 I'm spending.
If you farmed it out to a decent indie mechanic I'd guess it could be done for about $1000.  Keep that in mind if the automatic fails.
Mr. Drop Top
« Reply #4 on: July 31, 2010, 10:29:35 PM »
Humm that does help with a parts list of what needed to do the swap. I guess the best thing to look for would be a salvage car and take all the parts off that.  My list of things i wanna do with the car is growing longer and longer. Im glad all the interior and exterior is all done.
Nivola
    • http://www.nivola368s.com
« Reply #5 on: August 01, 2010, 02:27:38 PM »
I'm running a 9# JB Racing aluminum flywheel (part #520-040-215).  Like it very much.  :)
Correrai ancor più veloce per le vie del cielo...Nivola368s.com
Mr. Drop Top
« Reply #6 on: August 01, 2010, 11:57:43 PM »
Is your car an auto also? Is it worth the money and time?
Hodge
« Reply #7 on: August 02, 2010, 08:55:07 PM »
Manual Flywheels don't work with automatic transmissions.
Autos typically have light flywheels anyway, since they also have a hefty torque converter hanging off of the flywheel as well that has to spin.
1995 E36 318isc
Nivola
« Reply #8 on: August 02, 2010, 09:01:19 PM »
Quote from: Mr. Drop Top;95170
5-speed manual.
Mr. Drop Top
« Reply #9 on: August 02, 2010, 10:05:35 PM »
Soooooo... this will be no good to me?
« Reply #10 on: August 02, 2010, 10:13:54 PM »
Quote from: Mr. Drop Top;95203
I think thats what everyone is trying to say man.
If you get yourself a 5spd a good alternative is the m20 flywheel shaved down to about 12lbs or so. I wouldn't go any lighter because you may start to get chatter.
Anyway the answer is a definite NO, NO as in, it will NOT work with your autotragic :p
I must add that your car looks absolutely gorgeous...a 5spd would definitely make it MUCH better.
