OCTANE rating!
Author Topic: OCTANE rating!  (Read 3515 times)
FL318is
OCTANE rating!
« on: September 11, 2006, 10:02:17 AM »
What octane rate are you using?
Vladi
    • http://www.bmwzone.ro/forum
OCTANE rating!
« Reply #1 on: September 11, 2006, 12:06:55 PM »
I usually run on 95. I've currently got 100 and it's got quite a kick. :D
OCTANE rating!
« Reply #2 on: September 11, 2006, 12:18:41 PM »
93 only use 91+ and higher than that doesn't help b/c your car isn't tuned for it.  It will actually not have quite as much power if the octane is too high.
BrandC
OCTANE rating!
« Reply #3 on: September 11, 2006, 01:52:53 PM »
Quote from: Vladi
FYI Unless you've got a chip that knows how to advance timing enough to use 100 octane (which requires knock sensors), then it's just a waste of your money. Placebo effect.
16vcoffin
OCTANE rating!
« Reply #4 on: September 11, 2006, 06:08:17 PM »
Higher octane only means resistance to detonation (knock) or autoignition due to heat, pressures, etc, which on our motors are a very good thing, its never going to give you more in the way of performance though.
Check it out.
http://en.wikipedia.org/wiki/Octane_rating
mikesjo
OCTANE rating!
« Reply #5 on: September 12, 2006, 02:14:45 AM »
91/92 in Canada.
silverblades181
OCTANE rating!
« Reply #6 on: September 12, 2006, 12:31:45 PM »
91 when the prices were high, 94 when I could afford it. I also gased up at Petro Canada here in Quebec.
E30 318is 1991 (Brilliantrot)
Bayerisch Motoren Werke
16vcoffin
OCTANE rating!
« Reply #7 on: September 12, 2006, 04:09:30 PM »
The fucked up part about it is that octane raiting very from stat to state and country to country. Japan has MUCH 'better' gas than we have here. I guess thats why its the equivilant $6.50 a liter! Can you imagine having to fill up your GTR!?
Vladi
OCTANE rating!
« Reply #8 on: September 12, 2006, 04:26:19 PM »
Quote from: BrandC
I do have a suited chip and i've got the '94 E36 M42 engine. :rolleyes:
