MM pulse chamber intake manifold
Author Topic: MM pulse chamber intake manifold  (Read 13530 times)
colin86325
« on: July 19, 2010, 08:09:44 PM »
I think most of us have seen the pulse chamber intake manifold that Metric Mechanic sells:
I came across these pics of a 2002 intake manifold and it looks familiar (same principle on the headers, too).
Anyway, this was just something that I found interesting.
Hodge
« Reply #1 on: July 19, 2010, 08:11:32 PM »
That looks nice....
Never seen that on the M10 before...I have seen MM's pulse chambers though ;)
1995 E36 318isc
Nivola
    • http://www.nivola368s.com
« Reply #2 on: July 19, 2010, 10:55:10 PM »
Interesting.  Never seen the concept applied to exhaust headers.  (That's my M42B18 engine you've posted there...)  ;-)
Correrai ancor più veloce per le vie del cielo...Nivola368s.com
colin86325
« Reply #3 on: July 20, 2010, 08:06:59 AM »
Quote from: Nivola;94745
I hadn't seen headers like those either.
Hope it's ok that I stole your pic :)
Do you think the 15% increase in torque claim is accurate?
thedguy
« Reply #4 on: July 26, 2010, 05:20:37 AM »
Jim told me he used to put these on his intakes and headers when he built race engines for circle track guys in KC.  Biggest problem he had was that it smoothed the power flow so much the drivers couldn't feel the red line and kept blowing up engines.
Considering how Sam's engine felt on the top end, I'd believe it, I have no idea on actual numbers but the engine definitely didn't feel like it wasn't going to stop pulling.
Warsteiner
  • -Receive: 21
« Reply #5 on: July 26, 2010, 07:56:19 AM »
The engine wanting to keep pulling is more about the cam: duration, lift and timing. That is not the only thing but it is one of the major culprits. You could also over port your head. You can have all the pulling power up top and fall on your face down low. I bet Jim's motors have nothing to talk about below 4500rpm, all things considered that it's a stroker motor, and should make gobs of torque across the board and not just in the mid to upper range.  We all know it's the Torque that makes you feel the pull and not the Horsepower. HP numbers means nothing without the TQ.
Circle tracks are also a lot different from street driving as is road course driving. If you always want to use a gear lower than usual to stay above 4500rpm and keep it in the power band....well then there might be a bit more wear on the engine etc.
I have to say that they do look cool as hell and would definitely have tested this theory myself if I hadn't picked up a set of Dbilas ITB's.
Cheers,
~Ralph
colin86325
« Reply #6 on: July 27, 2010, 10:06:11 AM »
LOL, I guess having shift lights was too advanced an idea for the circle track guys ;)
e30boarder
« Reply #7 on: July 28, 2010, 01:10:21 AM »
is that a noticable increase in midrange power? or do you think its overkill for a daily driver? im in the process of rebuilding my m42 and im searching all over the forums for ideas. also it looks like something that could be easily fabricated.. right? i have a buddy that works at a fab shop and i figure he could hook it up for me. im not trying to spend 5g's rebuilding this bad boy
Nivola
« Reply #8 on: July 28, 2010, 02:29:14 PM »
Quote from: e30boarder;95004
There was a decent increase.  Daily driving was perfectly fine.
I no longer have the unit on my car (other projects :D ), so I may be looking to sell my MM Pulse Chamber Manifold and my BBTB (an increase of 3mm) which was done by Alpina527 in the UK.
e30boarder
« Reply #9 on: July 28, 2010, 02:41:48 PM »
Quote from: Nivola;95021
Nice.. let me know if you decide to do that
Nivola
« Reply #10 on: July 28, 2010, 10:56:27 PM »
Quote from: e30boarder;95024
I am definitely interested in selling.  Make me an offer via PM...
Nivola
« Reply #11 on: July 30, 2010, 01:02:21 PM »
Sold.
e30boarder
« Reply #12 on: July 30, 2010, 01:59:45 PM »
lol that was fast..
Mr. Drop Top
« Reply #13 on: July 31, 2010, 11:25:12 AM »
Is this only for the e30 m42? What about e36?
El-Kanal
« Reply #14 on: August 02, 2010, 02:46:32 AM »
I'm interested in using this on my project engine, but i want to mount ITBs on the lower part of the intake. I suppose this will still work for me though, or not?
Also how do you guys think would adding Injectors in the pulse chambers for high RPM use work?
