Author Topic: E36 M42 turbo install  (Read 11581 times)
Casey Belarde
« on: July 13, 2010, 04:15:41 PM »
has any one put a turbo into their E36 M42?
I have been looking for tips and pictures of others installs but all I see are E30 M42 turbo installs
thanks for the help in advance
Casey
clutchkick
« Reply #1 on: July 14, 2010, 12:55:50 AM »
google search....
Burt_318iS
« Reply #2 on: July 14, 2010, 08:06:34 PM »
Check back over the next few months.. I will be doing mine. Its a E36 and were gonna beef it up nice nice. :-)
bmwconnect
« Reply #3 on: July 14, 2010, 08:12:32 PM »
I have a done it on the e36...I will post pictures tomorow
Midnight YouTube Channel
Casey Belarde
« Reply #4 on: July 18, 2010, 07:53:35 PM »
any pictures bmwconnect??? I wanna see it, is it an under manifold turbo
found a kit on ebay looked pretty decent
bmwconnect
« Reply #5 on: July 18, 2010, 08:44:48 PM »
Hey was very busy this weekend ... Will post tomorrow for sure... My setup is bottom mount
bmwconnect
« Reply #6 on: July 19, 2010, 04:52:00 PM »
Pictures of my personal setup producing around 270-280whp@14-15psi on pump gas
Intercooled, 60Lb injectors, Motronic tuned, T3/T4 hybrid china turbo rebuilt with garret seals, internal wastegate, ebay knock-off blow off valve, stock internals(metric blue head studs)
El-Kanal
« Reply #7 on: July 21, 2010, 05:42:58 AM »
What mods were done to the AFM ? :) So you're running standard Motronic just remaped? Thanks
nuvolarossa
« Reply #8 on: July 21, 2010, 07:27:14 AM »
bmwconnect, do you have pictures of the underside? just curious about the wastegate clearance!
bmwconnect
« Reply #9 on: July 21, 2010, 09:21:19 AM »
Quote from: El-Kanal;94788
Afm is not modded... I opened it up to check the spring and pention meter wiper arm condition and yes it's the Motronic 1.7.2 with my tune
bmwconnect
« Reply #10 on: July 21, 2010, 09:23:37 AM »
Quote from: nuvolarossa;94792
I have none at this time but waste gate is internal anyway so there wouldn't be much to see... next time its up in the air I will gladly take some shots for ya though
bmwconnect
« Reply #11 on: July 21, 2010, 09:29:10 AM »
here is some pulls with 15psi and conservative ignition timing so at 3800rpm to 7000rpm it's at 16degs advance....When I run 20degs advance it's much quicker then those videos and if I advance to 23 degs I get some mild detonation so 19-20 degs is a good point for 91 octane
http://www.youtube.com/watch?v=tN-mR6P0MWc
http://www.youtube.com/watch?v=M38uEQetPKU
__________________
vtrigger77
« Reply #12 on: July 21, 2010, 01:01:03 PM »
nice thread guys.. im planning on putting a turbo on my 93 318is as well. i already installed cames and it made a difference so turbo is the next step..
bmwconnect
« Reply #13 on: July 21, 2010, 01:04:46 PM »
Quote from: vtrigger77;94813
Where are you located? I could come and tune it for ya
vtrigger77
« Reply #14 on: July 21, 2010, 01:05:58 PM »
im in socal.
