E30 M42 engine part out
Author Topic: E30 M42 engine part out  (Read 4790 times)
SiGmA_X
« on: June 07, 2010, 03:47:45 PM »
All parts have ~195k on them. Parts are pretty greasy in pictures – they will be hit with a pressure washer and lightly oiled after to prevent oxidation/rust. If you desire sandblasting, it can be done at a fee but be aware that it’s a slow process and will be charged for accordingly.
M42 cylinder head – 8 bent valves, slipped timing chain, no apparent cracks - $50 + SH
M42 short block – Block, timing chain case, pistons, rods, crank, rear main cover included – cold head-off leakdown showed an even ~15% after the motor had been sitting for 2yrs+ - $200 + SH
M42 upper oil pan – $45 + SH
M42 oil filter housing – $30 + SH
M42 valve cover – $45 + SH
M42 spark plug wires – $40 + SH
M42 factory coil pack – Shows minor rust – $30 + SH
M42 upper & lower intake manifold – $50 + SH
M42 throttle body – $35 + SH
M42 lower timing cover – $25 + SH
M42 upper timing cover – $20 + SH
M42 factory header – $40 + SH
M42 AC bracket – $25 + SH
M42 thermostat housing – $10 + SH
M42 alternator – $30 + SH
M42 starter - $30 + SH
93 325iS - Stock
86 325e - Stocker than Stock
Selfish
« Reply #1 on: June 13, 2010, 03:18:35 AM »
interested in the head if you still have it
SiGmA_X
« Reply #2 on: June 13, 2010, 01:50:22 PM »
I have it. I can get some pictures of it this afternoon. It appears fine, short of some bent valves. PM me.
93 325iS - Stock
fabsp
« Reply #3 on: June 18, 2010, 10:44:59 AM »
how much for the power steering pump needed in the UK cheers
zmannz803
« Reply #4 on: June 23, 2010, 04:38:24 AM »
Oil pans shipped to 29730?
algonequin
« Reply #5 on: June 23, 2010, 06:05:26 PM »
ill take the head shipped to 90715 have cash pr pay pall
rob_e30
« Reply #6 on: June 24, 2010, 12:12:13 AM »
Is the lower timing cover both the inner and outer?
