UGH, thats annoying. It really shouldn't be running any different with the 19# injectors. Does the Spanish 318is have an O2 sensor and cat? If not, it really can't adjust for bigger injectors during closed loop. But again, you're using the same size injectors as stock.
EDIT:
The stock injectors are 192cc and the EV6 injectors you installed at 208cc. If your car isn't equipped with an O2 sensor, then it will be running ~7% rich compared to stock. The O2 sensor in the US market cars allows the fuel system to adapt to the slightly larger injectors during closed loop operation (light load), and then go into open loop at high load where you would want the additional fuel flow.
