DISCUSSION
Electrical
Radio Fuse
Topic: Radio Fuse (Read 2898 times)
MelbourneMike
Radio Fuse
May 06, 2010, 07:04:48 PM »
Radio Fuse....Help me out...which one is the fuse for the radio...is there a diagram on here...strangely my rear driver's side window does not work either...but the radio i MUST have!! OH.....1991 318i.....its gotta be a fuse...right
Administrator
Legendary
-Receive: 60
Lives in the 80s
Radio Fuse
May 07, 2010, 09:42:08 AM »
I think the main e30 radio fuse is 12. The optional amp is 27, power antenna is 28. At least that's what is says in
post 4 here
Check the power window switch for corrosion. They're a bit of trouble to get apart but it's a common problem. Hopefully it isn't the motor itself. The switch terminals corrode & don't pass enough power to turn on the window motor. I usually sand mine with a bit of fine paper & lube them with di-electric grease.
DISCUSSION
Electrical
Radio Fuse
