Author Topic: Radio Fuse  (Read 2899 times)
MelbourneMike
Radio Fuse
« on: May 06, 2010, 07:04:48 PM »
Radio Fuse....Help me out...which one is the fuse for the radio...is there a diagram on here...strangely my rear driver's side window does not work either...but the radio i MUST have!!   OH.....1991 318i.....its gotta be a fuse...right
Radio Fuse
« Reply #1 on: May 07, 2010, 09:42:08 AM »
I think the main e30 radio fuse is 12.  The optional amp is 27, power antenna is 28.  At least that's what is says in post 4 here.
Check the power window switch for corrosion.  They're a bit of trouble to get apart but it's a common problem.  Hopefully it isn't the motor itself.  The switch terminals corrode & don't pass enough power to turn on the window motor.  I usually sand mine with a bit of fine paper & lube them with di-electric grease.
