Author Topic: Axle Nut Size?  (Read 5214 times)
dvmotorsports
Axle Nut Size?
« on: May 01, 2010, 04:14:42 PM »
Rather than running to the store, buying several sockets and then returning what I don't use, does anyone know the axle nut size for an 87 325ic?
Axle Nut Size?
« Reply #1 on: May 01, 2010, 09:41:16 PM »
Front or rear?
I believe its a 36 in front (not sure) and a 30mm in back, if I'm wrong then its just 30mm all the way around!
BlueBMW
Axle Nut Size?
« Reply #2 on: May 02, 2010, 11:08:59 AM »
I just did a rear wheel bearing on my 91 318is and I'm pretty sure it was either a 30mm or 32mm 12pt.
P. Kennedy
Axle nut
« Reply #3 on: May 02, 2010, 03:04:23 PM »
30mm.
Why would you want to use a 12-point?  It's torqued to like 230 lb-ft!
KenC
Axle Nut Size?
« Reply #4 on: May 02, 2010, 03:25:49 PM »
You need a thin wall for the rear too
BlueBMW
Axle Nut Size?
« Reply #5 on: May 02, 2010, 04:56:07 PM »
Thats right, i'm thinking of newer bmws that have 12pt nuts.  The e30 had a six point.
dvmotorsports
Axle Nut Size?
« Reply #6 on: May 03, 2010, 01:10:48 PM »
So 30mm thin wall 6pt is what I am gathering, right?
Axle Nut Size?
« Reply #7 on: May 07, 2010, 12:01:22 AM »
Quote from: dvmotorsports;91872
Yup, thats exactly what you need.
