DISCUSSION
Engine + Driveline
Axle Nut Size?
Topic: Axle Nut Size? (Read 5209 times)
dvmotorsports
Hero Member
-Receive: 1
Axle Nut Size?
May 01, 2010, 04:14:42 PM »
Rather than running to the store, buying several sockets and then returning what I don't use, does anyone know the axle nut size for an 87 325ic?
Administrator
Legendary
-Receive: 1
Axle Nut Size?
May 01, 2010, 09:41:16 PM »
Front or rear?
I believe its a 36 in front (not sure) and a 30mm in back, if I'm wrong then its just 30mm all the way around!
BlueBMW
Sr. Member
Axle Nut Size?
May 02, 2010, 11:08:59 AM »
I just did a rear wheel bearing on my 91 318is and I'm pretty sure it was either a 30mm or 32mm 12pt.
1991 318is (Sold to brother
P. Kennedy
Sr. Member
Axle nut
May 02, 2010, 03:04:23 PM »
30mm.
Why would you want to use a 12-point? It's torqued to like 230 lb-ft!
"If you think I\'m good...wait until you see my nephew." -
Ayrton Senna
KenC
Sr. Member
Axle Nut Size?
May 02, 2010, 03:25:49 PM »
You need a thin wall for the rear too
BlueBMW
Sr. Member
Axle Nut Size?
Reply #5 on:
May 02, 2010, 04:56:07 PM »
Thats right, i'm thinking of newer bmws that have 12pt nuts. The e30 had a six point.
dvmotorsports
Hero Member
-Receive: 1
Axle Nut Size?
Reply #6 on:
May 03, 2010, 01:10:48 PM »
So 30mm thin wall 6pt is what I am gathering, right?
Administrator
Legendary
-Receive: 1
Axle Nut Size?
Reply #7 on:
May 07, 2010, 12:01:22 AM »
Quote from: dvmotorsports;91872
Yup, thats exactly what you need.
DISCUSSION
Engine + Driveline
Axle Nut Size?
