Author Topic: e30 m42 problem  (Read 5388 times)
firehawk318is
    • http://www.firehawkse30.nl/
e30 m42 problem
« on: April 25, 2010, 07:54:04 AM »
hi
I have a problem
My engine runs cold 750 rpm idle and 1000 rpm when it is hot.
and if he is cold he misses power and when he turns warmer it better
maybe someone knows what the problem might be.
engine runs smoothly
grt Hilbert harm
PumpItUp
e30 m42 problem
« Reply #1 on: April 25, 2010, 06:18:58 PM »
tell him you're going to the zoo but instead blindside him with a vasectomy. :confused:
http://m42club.com/forums/showthread.php?t=2742
http://m42club.com/forums/showthread.php?t=3621
firehawk318is
e30 m42 problem
« Reply #2 on: April 26, 2010, 11:06:49 AM »
i replaced all the hoses and i cleaned everything.
and i have this throttle house
could number 7 be the trouble or can it be something else
Jorgeconrico
e30 m42 problem
« Reply #3 on: April 26, 2010, 03:02:58 PM »
You said you cleaned everything....What about your ICV??
firehawk318is
e30 m42 problem
« Reply #4 on: April 27, 2010, 03:32:47 PM »
i cleaned that to
BlueBMW
e30 m42 problem
« Reply #5 on: April 27, 2010, 04:01:59 PM »
My car idles lower when its cold and then usually a little higher when its hot.  As far as I'm concerned, it seems normal. :D
PumpItUp
e30 m42 problem
« Reply #6 on: April 28, 2010, 05:46:59 AM »
since your car works fine, but just has some small kinks, before you bother tearing stuff apart & buying new parts.. why not do the easy thing and get
-seafoam
and afterwards
-lubro moly fuel injector cleaner
that's like $17 total and doesn't require any labor
bad idle = good chance its dirty injectors
but that doesn't explain change under weather
clogged cat? (which works better when warm). seafoam cleans your cat
ofcourse you probably dont have a cat in the netherlands but it helps with throttle response
also low battery = bad idle. and cold is bad for batteries. sometimes in neutral you have to keep it up with accelerator or it will stall.
you're probably not some idiot with a bad battery but seriously if you make a lot of short trips, it will get low on juice and give you shit idle
theres always coil on plug kit! http://m42club.com/forums/showthread.php?t=9122&highlight=coil+on+plug coil on plug solves everything :confused:
« Last Edit: April 28, 2010, 05:49:58 AM by PumpItUp »
firehawk318is
e30 m42 problem
« Reply #7 on: May 03, 2010, 11:52:24 AM »
thanks for the tip.
my battery is oke and my alternator is good to so i will try other injectors.
my brother still has some m5 3.6 injectors will it be a good idea to try them or is it a bad idea.
PumpItUp
e30 m42 problem
« Reply #8 on: May 08, 2010, 04:04:51 PM »
http://m42club.com/forums/showthread.php?t=233&highlight=injectors
mustang in america, some vaxuall in europe
or just buy brand new from bosch. i think those are the options.
everyone says how awesome 4 pintle injectors are but i have yet to try them.
just read that thread, its only 10 pages
firehawk318is
e30 m42 problem
« Reply #9 on: June 01, 2010, 02:38:49 PM »
i replaced the injectors with ones from a s38.
it drives a little bit smoother but i did not solve the problem but when i replaced the injectors i have noticed that the injectors where going in the inlet manifold to easy and it make a sound if it  is leaking by the injectors in the manifold so i will go and get new seals and hope the problem will be solved.
i made a movie of the motor running
http://www.youtube.com/watch?v=5TSzTQyB2OI
