NisseJärnet
Author Topic: NisseJärnet  (Read 17268 times)
NisseJärnet
NisseJärnet
« on: April 25, 2010, 07:01:20 AM »
Hi everyone!
Im pretty new here, living in sweden so my english is not that good :rolleyes:
This is a great forum! Im pretty new to the M42, but i know the M20 inside out :)
I have a E30 M20 turbo putting out pretty good power but recently started building a E30 M42 turbo with a friend, and then when we already was in the garage i picked up a complete M42 from a E36 and a complete but taken apart E30 M42 engine and started swaping the E36 motor in my winter-drifting car, 318i M40.
So we have our hands full at th moment, the 318is turbo is gonna be dynoed in a few weeks and has some small work left, IC piping, exhaust, oil feed to turbo and some other small things. More info on this car soon!
I started the 318 M42 swap yesterday efter some electrical work and everything seems to be working, so now its time to build exhaust and fix the drive shaft and then test it on the road :)
I used a -93 E36 M42 engine complete with ECU, harness, gearbox with clutch cylinder etc, M40 mounts and brackets. My rive shaft seems to be like 1cm too long though so ill have to to something about that, ill be back on that one.
The E30 M20 6 speed turbo is pretty much turn key from last year, just made some small mods and gonna check it out in the dyno soon as well.
Will post some pics and videos soon! If anyone wants to see :)
-88 E30 325i M50 6spd turbo, 764whp
-89 E30 318i M42, 140hp COP conv. (E36 engine + gearbox, 3.73 188 diff)
-90 E30 318is M42 turbo, 240whp (sold)
http://www.youtube.com/nissejarnet
NisseJärnet
NisseJärnet
« Reply #1 on: April 26, 2010, 04:43:36 PM »
Finished the E36 M42 swap yesterday, works lika a charm! Much more fun to drive it now than before with the M40 hehe.
Jorgeconrico
NisseJärnet
« Reply #2 on: April 26, 2010, 09:29:10 PM »
Quote from: NisseJärnet;91414
Yes
dinu.negrean
NisseJärnet
« Reply #3 on: April 27, 2010, 05:34:25 AM »
Quote from: Jorgeconrico;91502
Yes
+1, also interested.
Great work man! Some info on the setup would be much apreciated. Which turbo did you use? What is the size of the IC, pipes size, exhaust size, soft?
Looking forward to the progress of your work.
NisseJärnet
NisseJärnet
« Reply #4 on: April 27, 2010, 09:03:54 AM »
The 318is M42 specs:
Mitsubishi EVO8 turbo
Home made puls split manifold
630cc injectors
MS ECU with stock coils
600x300x102mm intercooler
Bosch BOV
3" intercooler pipes
3" exhaust
ARP head bolts
O-ring block
M50 non vanos rods for lower comp
M20 flywheel with sinter clutch and 325 E30 pressure plate
Right know im building the ic pipes, exhaust and oil feed to the turbo :)
Videos of the M20 turbo can be found here http://www.youtube.com/nissejarnet
Videos of the is turbo will come as soon its finished :)
NisseJärnet
NisseJärnet
« Reply #5 on: April 27, 2010, 06:59:28 PM »
is turbo pics:
Cleaned stock pistons:
Didnt bother to paint the block:p
E30 M20 turbo:
A little street racing:
E30 vs. American muscle
3:d place for me (upper left)
E30 with M42 E36 engine
Ill try to get some more engine pics of the is turbo tomorrow!
NisseJärnet
NisseJärnet
« Reply #6 on: April 28, 2010, 10:35:40 AM »
More E30 is turbo pics!
Nice rebuild head
Clean and ready to go inside the engine!
Airpump with weird exhaust housing
Ready for the head!
More pics soon :)
NisseJärnet
NisseJärnet
« Reply #7 on: May 01, 2010, 06:22:21 PM »
Home made manifold + turbo.
To bad i didnt TIG weld the manifold, but hey that doesnt make the car faster :)
Had to cut a mounting thingie off the compressor housing to clear the manifold, tight fit =P
NisseJärnet
« Reply #8 on: May 01, 2010, 09:41:57 PM »
Wow bottom mount! You don't see that too often. Can we see some pics from the bottom?
NisseJärnet
NisseJärnet
« Reply #9 on: May 02, 2010, 04:44:13 PM »
Quote from: dude8383;91786
Can take some pictures tomorrow :)
NisseJärnet
NisseJärnet
« Reply #10 on: May 04, 2010, 05:47:16 PM »
A short test movie featuring the E30 with E36 M42 engine :) 40-160km/h starting in 2nd.
http://www.youtube.com/watch?v=EKYbGeekC4M
TOKYO
NisseJärnet
« Reply #11 on: May 05, 2010, 10:27:38 AM »
I saw a white m20 turbo in action.... :)
It goes like the devil from hell... ;)
http://www.youtube.com/watch?v=LWEW0UL8ako&feature=channel
http://www.youtube.com/watch?v=BRDiULRvf0E
TRY HARDER
NisseJärnet
NisseJärnet
« Reply #12 on: May 05, 2010, 04:37:35 PM »
Quote from: TOKYO;91987
Wuhuu there i am :D
One more vs the V10 E30 http://www.youtube.com/watch?v=3FSzFesgDLg&feature=related
I need better tires:rolleyes:
TOKYO
NisseJärnet
« Reply #13 on: May 06, 2010, 03:02:16 PM »
You do not need anything, you have everything ... ;)
My friend drive similar turbo conversion, car is going great and the sound is amazing...
Car in the middle..., this is some practis for king of europe last week!!!
http://www.youtube.com/watch?v=JLNwvSRc0CM
http://www.youtube.com/watch?v=LVsXhMThsOI&NR=1
TRY HARDER
NisseJärnet
« Reply #14 on: May 06, 2010, 11:58:54 PM »
That V10 E30 is really something!!!!
I love the fact that you posted the E30 vs the Viper and then the turbo E30 vs E30 V10...you get a pretty good idea of just how quick the V10 E30 is!!
