DISCUSSION
Engine + Driveline
alternator belt
Topic: alternator belt (Read 2463 times)
RED IS 91
Hero Member
alternator belt
April 23, 2010, 06:18:46 PM »
My alternator belt was squealing because it was loose . My adjustment had run out and I couldn't get it any tighter.I thought it had stretched but when I installed a new belt I just about ran out of adjustment on it. Has anyone else run into this issue?
The Little Car That Could
214,000 miles
strad
alternator belt
April 28, 2010, 01:01:04 PM »
What I would check is to make sure the new belt you put on is actually the specified oe length.
When I replaced belts on my M42 I did not have any problems with length.
92BMW318is
alternator belt
April 28, 2010, 04:37:16 PM »
there should be two tighting bolts atleast there is on mine
try lowering the water pump too, then move the alternator over as far as it can go
both the water pump and alternator should swivel
DISCUSSION
Engine + Driveline
alternator belt
