Author Topic: coolant leak  (Read 2155 times)
freek454
coolant leak
« on: April 11, 2010, 12:21:05 PM »
I have an m42 with a coolant leak rear engine driver side heater hose that connects to the head. I took off the hose and found the outlet tube was corroded and may need to be replaced. Is the outlet tube bolted on, or a piece of the head? Can I fix this problem without removing the head? :confused:
coolant leak
« Reply #1 on: April 11, 2010, 02:52:51 PM »
I think it's separate, but a press-fit bit of tubing.  I'd be tempted to JB Weld a pipe in there if it's really bad.
Phreon
coolant leak
« Reply #2 on: April 11, 2010, 03:25:49 PM »
You could buy a NPT pipe tap for a couple of dollars and screw a fitting or pipe nipple in there.
