Author Topic: e-brake rebuild  (Read 1941 times)
max123
e-brake rebuild
« on: March 25, 2010, 12:26:34 AM »
Just out of curiosity, I've been chasing a wierd clunk and have replaced virtually the entire suspension (and I mean everything).  Just wondering, is there anything in the e-brake setup that can go and cause strange noises, such as a bad spring causing sudden/delayed release while driving.
Anyway, the car has 250k on it and I'm guessing the e-brake has never been touched, so its probably about time to pull the rear disks and take a look.  Has anyone done this - what's needed?
Cheers,
DesertEagle
e-brake rebuild
« Reply #1 on: March 26, 2010, 02:42:50 PM »
The ebrake has 4 springs and two shoes per wheel.  If a shoe cracked or a spring broke, that could cause noise and/or the shoes to stick to the wheel.  It seems to me, however, that a sticky caliper is more likely to cause "sudden/delayed release while driving."  You have to remove the caliper, then the rotor before you can get to the ebrake, so might as well check the caliper first.
