Author Topic: Lifter Replacement  (Read 2502 times)
sporkfan
Lifter Replacement
« on: March 10, 2010, 07:40:47 AM »
I've tried Seafoam, Lucas Valve Treatment and I've currently got Marvel in the sump, but my valve tick isn't going away.
Do I need to get the BMW tool to compress the valves or is there a different way to unbolt the cams from the head to get at the lifters. Any advice would be appreciated.
dinu.negrean
Lifter Replacement
« Reply #1 on: March 10, 2010, 09:27:33 AM »
Of course the bmw tool is the best option. If you can't have it, you have another tool: patience. You must unbolt the cams by turning each bolt 1/4 turn on time with patience and a lot of care. They can EASILY break.
sporkfan
Lifter Replacement
« Reply #2 on: March 10, 2010, 09:42:04 AM »
Is there a pattern to the 1/4 turn method?
flyinglizard
Lifter Replacement
« Reply #4 on: March 10, 2010, 09:18:20 PM »
Start torquing around the depressed lifters. The rear lobes are down at TDC.  Work from there, keeping even depression and threads showing  on the studs. .  Moving around as you go. MM
 20 years of renting race cars
