Author Topic: 94 318 sedan Track/toy car build FS  (Read 3728 times)
workaholic
« on: March 02, 2010, 03:55:58 PM »
Ok I'll start out that I spent several years building this car but due to financial troubles and being unemployed for a year to get re-employed but at a substantial pay cut I'm having to sell my project. Including the cost of the car I have over $30k into this thing. I will entertain offers as long as they are reasonable. I'll start the pricing out at $17500 OBO.
What it needs to be completed
Suspension (the cup kit isn't adjustable to accomidate the new wheel/tire combo)
Flares (I was planning to use 240sx flares to finish it off)
Megasuirt install finished and tuned. From speaking with various different sources This setup should make 500+BHP at 25psi.
Mods list
Engine
.062 soft anneald copper headgasket
Ross 8:1 full floating billet race pistons with full floating pins
Block Was resleaved for a stock bore
All internals were checked and the rods were "wet magged"
Gasket match P&P on the head
+40lbs/in valve springs
5 angle valve job
PWR 32X radiator with alum. hoses
Raceware headstuds
Permacool 3000cfm electric puller fan
Fuel
Bosch 60lb/hr injectors
Holley 70gph fuel pump (comes out to about 280lph)
Holley FPR
Drive train
Bimmerworld 10lb e36 m3 flywheel
Spec STg3 organic e36 m3 clutch and pressure plate (450tq capacity)
S50 5spd transmission
Understeer e36 m3 SSK
E36 m3 rear subframe and associate drivetrain parts
E36 m3 rear brakes
3.15LSD rear diff
Active autowerks rear diff braces painted blue
Rear subframe reinforcement plates welded in place
Rear swaybar reinforcement plates welded into subframe
E46 330 front brakes
Hawk HPS pads front and rear
Stainless brake lines front and rear
Turbo Setup
Megasquirt 2 prebuilt by DIY auottune and partially wired
Zeitronix ZT-2 wideband
T3/t4 hybrid with <5 miles .060/.063 purchased new direct from Garrett
stg 5 wheel with 270deg thrust bearing
28x11x3.3 intercooler (will support 550whp)
Greddy profecB spec 2 boost controller
Greddy turbo timer
3" exhaust from turbo back (first 6" is 2.5" due to space restrictions)
Uses a dynomax bullet resonator and a magnaflow stainless muffler
Exhaust side of turbo ceramic coated blue
Suspension
TMS RCCA's
H&R cup kit with GC RSM's (~20k miles on this)
TMS swaybars front and rear
Ireland Engineering motor mounts
Powerflex rear subframe mounts
Ireland Engineering transmission mounts
GC RTA shims
Wheels/tires
Et15 18x8.5 Breyton inspirations painted smurf blue
265/35/18 fuzion ZRI rubber with 0 miles
Interior
5pt blue harnesses for driver and passenger
Speedware sparco seatmount
Autometer ultralight guages
   Boost/vac, oil pressure, oil temp, h20 temp
Kirk race 4pt. cage powdercoated smurf blue.
Carbon Ebrake handle
Blue carbon shift knob
otherwise stripped
Body/exterior
Real carbon emblems
Euro smoked tailights
Clear front corners also smoked
VIS euro carbon hood (no holes for pins yet)
VIS carbon trunk (modified to run a locking hood pin on either side)
Carbon fuel door
Depo glass lense projector headlights with 55w 6k lows and high beams
with stoneguard
spares
Complete cylinder head with cams
2 head gaskets with the material to make 3 more and the pattern to do it.
Intake manifolds
The attached pics are a bit older and with a different set of wheels. The only different about the exterior is the wheels.
If I can't sell this thing as a whole I will part it out. All though I wont be able to part it out for a couple weeks when I get the space to do it. Since I know that even if I said I wanted to sell it whole people would still ask for parts anyways I'll do this. If you are only interested in a part off the car send me a PM and PM only of the part you are interested in and your offer for it. please keep in mind that this stuff has at most (with the exception of items labeled as such) brand new and just been installed. So base your offer accordingly.
Thanks,
Tom
« Last Edit: March 15, 2010, 05:06:05 PM by workaholic »
workaholic
« Reply #1 on: March 05, 2010, 04:47:39 PM »
really? zero interest...........
Tom
Nomadic
« Reply #2 on: March 07, 2010, 02:46:57 PM »
Why not finish the project.... seems like you are very close. Get the motor in and running.   Run different wheels and you can skip the fender flares which are a huge time suck...    You can sell the stuff like the carbon hood / trunk, wheels, & HIDs to raise a bit of $$
workaholic
« Reply #3 on: March 07, 2010, 03:43:20 PM »
Quote from: Nomadic;89035
Because to get this car to a drivable manor it would take a significant amount of money that I do no have due to taking such a large pay cut. Unless e36 offset wheels were swapped on the car is not driveable without flares. The cost of the flares or a different set of wheels WITHOUT tires are the same. then I would have to get tires. not including the cost of dyno time to get it all tuned. then comes being able to actually support the car which I cannot due to the cost of it.
That and the motor is in the car and has been for a few years.
Tom
workaholic
« Reply #4 on: March 15, 2010, 05:04:43 PM »
After doing some research due to complaints about my asking price. I have found that cars of a similar genre (turbo cars). I have found that I had the price too high. So as a conclusion I'm going to lower the price to $10,000OBO.
Thanks,
Tom
workaholic
« Reply #5 on: March 16, 2010, 09:22:45 PM »
Here's a few more pics. I've decided that if after 6-8wks of being listed for sale the car doesn't sell i'm just going to keep it.
Thanks,
Tom
