Author Topic: electric fan  (Read 6144 times)
4banger
electric fan
« Reply #15 on: March 03, 2010, 08:55:36 PM »
Quote from: Ryann;88801
Changing DC motor rotation is as simple as flip flopping the two leads.
correct.changing polarity is that simple. ;)
:D:D[SIGPIC][/SIGPIC]
deekay
electric fan
« Reply #16 on: March 03, 2010, 09:15:38 PM »
just a note- when i did my e-fan setup, it was originally a volvo/e36 puller fan, but i installed it in the front as a pusher.
people commented that it "wasn't going to work as well" that way, because the blades are shaped to move the air in one direction. it seems to work plenty well for me; pushing the AC button results in the needle moving to the left immediately and quickly. probably just because it's way more fan than the car actually needs.
i like the functionality of repurposing the AC button to be the "auxiliary cooling" button, and i am very happy with the way the engine bay looks with all that room between the radiator and the engine. we had to go to home depot to get some thin pipe stock to make stand-offs with, and kragen to get a generic e-fan mounting kit, but overall cost (other than the fan) was $15 or so. looking at your shroud you might have to do the same, because the body of the motor may protrude past the mounting surface on the shroud. anyway if you have questions/want advice shoot myself or peerless a PM, we did the install at his shop on a friday night while drinking a bunch of beer :D
electric fan
« Reply #17 on: March 03, 2010, 10:50:29 PM »
Its a 3 wire 2 speed motor with built in resistor for low/high speed.
Quote from: deekay;88808
How did you reverse flow direction of the fan?
deekay
electric fan
« Reply #18 on: March 05, 2010, 01:49:47 PM »
Quote from: tjts1;88819
IIRC, we switched polarity and used only the high-speed lead.
edit: forgot to mention we had to up that circuit's fuse to 30A also. do that and save yourself a couple blown 15A fuses ;)
« Last Edit: March 05, 2010, 02:09:32 PM by deekay »
