Author Topic: Chip Install How-to??  (Read 3235 times)
318idol
« on: February 15, 2010, 01:19:32 PM »
Has anyone put together chip install how-to article?   I know where the DME is, but not sure how to remove it.  There's a plastic cover over it.  Tips?
I have a new MarkD chip.  Eager to try it out.
Also, should I get a grounding strap to work in the innards?  Thanks, Gary
RED IS 91
318idol
« Reply #2 on: February 16, 2010, 12:33:23 PM »
Thanks...I saw that...but no photos.  I'm sure I can figure it out.  Is the grounding strap necessary?  Or are there other ways to prevent static electricity from being an issue?
RED IS 91
« Reply #3 on: February 16, 2010, 02:14:14 PM »
It's like working on a home computer ,when you sit down or work on it ground yourself to something before you work on it. avoid things that cause static electricity like wool clothes or a rug .Just touch something metal before you start to work on it so you discharge yourself.
good luck
more reading http://www.e30tech.com/forum/showthread.php?t=43659&highlight=replacing+chip
There's a pic of the chip installed in this thread......scroll down
http://www.m42club.com/forums/showthread.php?p=74529
« Last Edit: February 16, 2010, 02:25:00 PM by RED IS 91 »
ecuconnections
« Reply #4 on: February 17, 2010, 12:34:09 PM »
