So these are finally ready to go. I'll have mounted pics tonight showing the caliper mounted on the car. I don't have the rotors yet, but this should not be an issue.
See this thread for any questions pertaining to the setup.
http://www.e30tech.com/forum/showthread.php?t=83511Things to think about with this setup:
Will my wheels work with this setup?
- There are no set in stone answers from what I can see. I know that a 15" rim might still be pushing it for clearances around the caliper so take that into account. The biggest issue is going to be your caliper to spoke clearance. This setup might require you to run a spacer. I can't not tell for sure though if it will in fact need it.
What else will you need for this conversion?
- If you follow the thread created by Tchao in the Brake subforum, you should be able to figure out what is required.
As stated before, these are fabbed from a 1/2" x 1.000" piece of flat bar, fully CnC'd flat and then stepped. All the holes are drilled at the same time to maintain the correct placement. The holes will be tapped for m12x1.75 thread and I will be including the hardware required for mounting.
I am going to work this in a stepped fashion.
0-3 people = $75 shipped
3-6 people = $70 shipped
6-10 people = $65 shipped
10+ people = $60 shipped
This GB will run for 2 weeks at the end of which I will be purchasing the material to make the sets. Payment will be required with 3 days for the GB's end so I can pay the fab shop. There maybe a lead time of a week or two depending on the amount of brackets purchased.
I will ship out side of the US but I can offer the same rates listed above. Please contact me to work something out.
Also, please keep any question and/or negative input to a PM please.
Pics of the brackets:
Line adapters -More info coming on those.
Buyer's List
1.) M20_fever <--- Brackets and Adapters
PAID!!!!2.) FWDSUCKS <--- Brackets and Adapters
PAID!!!!3.) ejohnson <--- Brackets
4.) TopLap <--- Brackets Now at $70 shipped!!!!
5.) Wishno87 <--- Brackets and Adapters
PAID!!!!6.) whodwho <--- Brackets
PAID!!!!7.) ss45466 - Brackets & adapters <--- Now at $65 shipped!!!!
PAID!!!!8.) Unregistered Guy - EP - Brackets and Line adapters
9.) enildeR - Brackets (m42club.com)
10.) LouieD - Brackets
11.) im2gq4u01 - Brackets
12.) etta87 - Brackets
PAID!!!!Thanks!
Matt
ten2doyle102
Phone: (920)-213-2786
