Author Topic: Cant rev past ~3000rpm - Automatic Transmission  (Read 2417 times)
ophdeheezy
« on: August 19, 2006, 11:24:17 AM »
Hi,
I've searched but couldnt find anything relavent.  I have an 85 318i Auto.  The problem is when I drive the car in the normal automatic 'drive' mode, the rpms will never go above ~3000rpm.  Even when I floor the pedal, it wont downshift.  It'll always shift at ~3000rpm.
I can drive the car fine if I shift the gears manually but I would like to fix the problem so I wouldnt have to do that.  Is it the tranny?  TPS sensor?
Any help would be appreciated.  Thanks!
James
Jtuner
« Reply #1 on: August 19, 2006, 01:58:33 PM »
I know absolutly nothing about the m10 :( :(
ophdeheezy
« Reply #2 on: August 20, 2006, 04:20:39 AM »
FL318is
« Reply #3 on: August 20, 2006, 05:30:34 PM »
I will ask my Tech!
Would a 325iS replacement tranny work?  If it does and you need one, I know where there is a beautiful rebuild.
2002maniac
« Reply #4 on: August 21, 2006, 01:31:27 AM »
Quote from: FL318is
nope
