OoOoO...k so we all know i have a bad rep at explaining things so ill try to explain this the best way i can....ok... my take off suxs, i don't think that when i take off from clutch to gas the engine will bog down as if its ready to stall out then the rpm will raise up according to pedal pressure so...picture it like this give gas to to full throttle while releasing clutch in a some what of the line motion, from idle (at 900 rpms..well mine) gas,off clutch, engine bog! then the engine will rev normally to were ever so why....and why cant i dump the damn clutch either? is it the tranny? the clutch? what?....i hope i explained that in a way you can understand cause quite frankly i suck at it....
