Author Topic: bin file with eprom reader  (Read 6101 times)
persianbmw
« on: January 30, 2010, 12:46:31 PM »
anyone have a detailed write up on how to pull the bin file off a chip with an eprom reader
« Reply #1 on: January 30, 2010, 04:43:06 PM »
I was thinking about setting one up, but my budget got slashed.  I'll post if I get anything.
Editing will be the bigger problem, I suspect.
persianbmw
« Reply #2 on: January 30, 2010, 11:05:37 PM »
i dont really need to edit i just have to find a idiot proof way of pulling the file and sending it to a tuner so theyll write me a chip since my dme isnt currently supported and i need it asap.
« Reply #3 on: January 31, 2010, 09:37:07 AM »
Finding someone with an EEPROM chip reader would be difficult.  I'm thinking a lot of coders should have one.  Find an LS1 guy maybe?
persianbmw
« Reply #4 on: January 31, 2010, 06:56:47 PM »
i dont need help finding the reader i need a faq on how to get the files i need off my chip using the reader.
ecuconnections
« Reply #5 on: January 31, 2010, 09:26:12 PM »
I take it you got the eprom reader I suggested ?
« Last Edit: January 31, 2010, 09:32:34 PM by ecuconnections »
persianbmw
« Reply #6 on: February 01, 2010, 11:08:06 AM »
not yet i wanted to make sure i would be able to use it before i buy it. id dont want to dick around with my ecu till im 100% on what im doing.
on a side note bears do you know if i can just pop in another 318i ecu which is more common? or is the engine mated to the ecu so as to not allow that.
« Reply #7 on: February 01, 2010, 12:31:58 PM »
Do you have an e36?  You can't easily swap a DME/ECU unless you get a dealer (or coder) to realign it to the car.  No such trouble on the e30.
persianbmw
« Reply #8 on: February 01, 2010, 03:43:06 PM »
yeah im e36 93 engines a 94
persianbmw
« Reply #9 on: February 06, 2010, 08:35:56 PM »
anyone? diy on bin extraction
nickmpower
« Reply #10 on: February 06, 2010, 08:53:57 PM »
use tunerpro
ecuconnections
« Reply #11 on: February 07, 2010, 11:51:56 AM »
Quote from: persianbmw;86832
My friend what hardware are you using to extract the bin file??
