DISCUSSION
Swaps, Turbos, Buildups
volvo & merc turbos
Topic: volvo & merc turbos (Read 2966 times)
4banger
Sr. Member
volvo & merc turbos
January 30, 2010, 01:25:53 AM »
could either a merc or a volvo turbo be used on a m42 build?
:D[SIGPIC][/SIGPIC]
Administrator
Legendary
-Receive: 60
Lives in the 80s
volvo & merc turbos
January 30, 2010, 06:59:56 AM »
I've heard of a SAAB/VW units being used for builds...or Nissan T04/T03 hybrids. I'm no expert but I'd guess the compressor map is more important than the OEM.
http://www.rbracing-rsr.com/turbotech.html
http://forums.bimmerforums.com/forum/showthread.php?t=258035
deekay
volvo & merc turbos
January 31, 2010, 10:47:56 PM »
^ agree with dave. i picked up a turbo off a 524td, which is the same trim & ar as the usual volvo/saab turbos. i'm not aware of any nissan applications that have a T3/T4 hybrid, and the ones that do have straight T3's (RB20, RB25, VG30ET) usually have some kind of wierd proprietary turbine housing. nissan's four-banger turbos, usually T25s, may be a bit smaller than you really want.
volvo/saab/etc turbos all use the normal 5-bolt housing. i picked up one of these integral wastegate assemblies from ATP turbo:
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TP&Product_Code=ATP-WGT-023&Category_Code=
which should make the install easy, as all you need is a v-band on the downpipe to match up to it.
good luck-
"the e30 colin chapman would have built"
4banger
Sr. Member
volvo & merc turbos
January 31, 2010, 11:14:11 PM »
i was just wondering. there is a shitload of turbo cars in the local pickApart. bought a 85 2door with no running gear and was given free range to strip a early 80's 320i. gonna do a lowcost 318/m10 turbo build.
:D[SIGPIC][/SIGPIC]
DISCUSSION
volvo & merc turbos
