Author Topic: timing chain broke  (Read 2885 times)
318lotis
timing chain broke
« on: January 25, 2010, 05:20:32 PM »
my e30 m42 318is bit the dust , timing chain broke, i was speeding pass a semi 80 mph.   I found a 1992 e36 318, would anyone know if this engine would  drop in our car without too much difficulty?
timing chain broke
« Reply #1 on: January 25, 2010, 05:32:36 PM »
I think they're a straight drop-in, except you'll have to swap the intake manifolds.  This has come up before, someone will chime in with a more positive answer.
Torque
timing chain broke
« Reply #2 on: January 25, 2010, 06:16:52 PM »
Aside from the addition of the DISA intake manifold and knock sensors, they're identical. Put your manifold on it and leave the knock sensors unplugged (or remove them); everything else is the same.
colin86325
timing chain broke
« Reply #3 on: January 25, 2010, 06:32:06 PM »
You'll need the E30 oil pans also.
318lotis
timing chain broke
« Reply #4 on: January 25, 2010, 07:53:08 PM »
so, i would keep the oil pans from original m42 engine, and place them on new engine, good tip, also, and no knock sensors are needed, and manifolds are different . this was great help. thanx for tips.
timing chain broke
« Reply #5 on: January 25, 2010, 08:23:23 PM »
I think the exhaust manifold is slightly different. Strip your existing engine.
