Author Topic: Coils, spark wires correct seqence :)  (Read 5941 times)
92BMW318is
« on: December 20, 2009, 04:39:21 PM »
sorry guys to repost this, the other thread was getting messy as hell well i found the cylinder firing sequence and this is that fixed my problem with crossing spark wires
      here is a illistarted diagram by me, haha it does its purpose
Right!! :)
All BELOW ARE Wrong
« Last Edit: December 22, 2009, 06:08:57 AM by 92BMW318is »
« Reply #1 on: December 20, 2009, 06:39:14 PM »
OK, so did this fix your problem?
And FYI, the cylinders are number 1 through 4 from front to rear, so the coils would have the non-sequential numbering, not the cylinders.
« Reply #2 on: December 20, 2009, 07:49:07 PM »
Quote from: ak96ss;83320
+1 on that.
I have much shorter Volvo wires which you can actually follow from coil to plug.
92BMW318is
« Reply #3 on: December 20, 2009, 08:32:24 PM »
the picture is still right tho
i was going by piston firing
92BMW318is
« Reply #4 on: December 21, 2009, 10:44:10 PM »
okay guys fixed it sorry about that
dvmotorsports
« Reply #5 on: December 21, 2009, 11:25:26 PM »
Quote from: 92BMW318is;83314
All BELOW ARE Wrong
Broheim, this is the same thing as in the picture. I assure you it's not wrong. Just rotated 45 degrees.
fiftytakedowns
« Reply #6 on: December 21, 2009, 11:37:15 PM »
i dont understand, The wrong diagrams seem right to me.
92BMW318is
« Reply #7 on: December 22, 2009, 06:04:06 AM »
Quote from: dvmotorsports;83388
what model is this for?
dvmotorsports
« Reply #8 on: December 22, 2009, 11:10:28 AM »
318 of course
dwtaylorpdx
« Reply #9 on: December 22, 2009, 12:00:07 PM »
Wonder if someone installed the coil packs in his car in a different order and just moved the coil input wires back at some point? LOL That would be evil....
Dave
92BMW318is
« Reply #10 on: December 22, 2009, 03:23:48 PM »
this is what my coils look like, along with spark plugs, i dont understand why mine is diffrent
« Reply #11 on: December 22, 2009, 04:07:22 PM »
Yup, they are different.  You'll have to chase those wires back to the DME.  Won't take you long.
dvmotorsports
« Reply #12 on: December 22, 2009, 08:25:31 PM »
Just get the pinout numbers and check resistance from the DME harness to the coil harness. For example when you plug into pin #25 and you find the resistance on the other end, that will be cyl #1. Then move that to position number one as I showed in the diagram. You will also need to go to the boneyard and get the bracket to mount the coils correctly.
dwtaylorpdx
« Reply #13 on: December 22, 2009, 10:36:49 PM »
Or convert to coil on plug.
Dave
« Reply #14 on: December 23, 2009, 01:23:49 AM »
Why are there zip ties on your spark plug wires?
