Author Topic: Post your suspension setup  (Read 29097 times)
dvmotorsports
« Reply #30 on: February 10, 2010, 11:35:04 AM »
^That is dope. You have the AST setup similar to what I want.
Massimo
« Reply #31 on: February 25, 2010, 12:07:50 AM »
^^ Dam i wished I had more time to track my car and had vorshlag 4100 series on my beast.
Even better i wish i was a vorshlag dealer for Australia. Lol
deekay
« Reply #32 on: February 25, 2010, 12:26:06 AM »
tokico blue shocks (e36 non-M front, e30 rear), with vorshlag camber plates in the front
h&r sport springs for Z3 1.9
stock swaybars with TMS reinforcement front & rear
e36-s52 control arms with treehouse lollipops
e36 non-M knuckles and brakes front
z3 1.9 trailing arms and brakes rear
AKG bushings everywhere except the rear shock mounts, which are e46-cabrio
no spring pads in the front, 10mm pads in the rear and removed the cabrio trunk anvil to reduce rubbing
e38 style5 16x8's with KDW 225/45-16
i think that's everything... have spent more money on suspension for this car than anything else.
even with the fenders pulled very aggressively, it rubs in the rear when i hit a bump on the freeway at 80mph+; if i had used 318ti trailing arms i wouldn't have this problem, but i love how the wider rear track looks. if i could do it over i would use vorshlag e30 318is springs and billy sports for an e36M in the front and e30 in the rear, rather than the non-M stuff... but honestly the handling is fantastic considering how daily-drivable the ride quality is and i don't regret it, especially since i've gone top-shelf with everything else, if i decide i want to swap the shocks and springs out someday i don't have to touch anything else.
if you do follow my advice and go with vorshlag springs, /get a skid plate from peerless/ - not optional. my car is not that low in the front and i have kissed the reiger lip a couple times, and live in fear of the day that i gronch the oil pan.
dvmotorsports
« Reply #33 on: February 25, 2010, 03:00:06 PM »
I have a custom D2 setup when spun all the way up is -2" in the Front and -1.5" in the rear. When completely dumped, i can lay pan.
longtallsally
« Reply #34 on: April 04, 2010, 02:11:07 PM »
Just the typical H&R Sport and Bilstein sport setup.  The green version of rear subframe bushings and I think the same for the trailing arms (PO installed all the bushings).
I personally think the ride is very acceptable for the street and the crappy (yes I said crappy) German roads I'm currently navigating daily on with it.  This is also with the stock basket weaves with something or other all season tires.
In my other E30s (325is) in the past I had Ground Controls with Koni one way adjustable shocks.  The spring rates I had were a bit extreme at 450F and 600R and then I went back to 375F and 450R.  It rode like a RACK.  However, the handling was absolutely ridiculous.  The only thing they needed was the camber correction kit to be just about perfect.  I'm older and less inclined to be that uncomfortable now and think I have just about the perfect compromise now.
I have to disagree mildly with Godfather on the bigger sway bars, though.  I learned a long time ago from some very serious autocrossers (I just did it for fun) that you should tune with the springs and not the sway bars.  It does make sense if you want to keep all 4 paws on the ground.  I do agree on the stock rubber for the bushings, though.  Remember that you live in CA where the weather makes changing them easy.
tony92ic
« Reply #35 on: April 09, 2010, 10:55:20 PM »
Hey, I've got the same suspension as John W.
Stock M3 springs, Bilstein Sports, Offset CABs and e46 rear mounts. I removed the spring pads and, like BMWMAN, went with all rubber bushings. Huge ride quality improvement and no noticable loss of handling on the street. Actually may be better. The poly/delrin often lost traction on the crappy street surfaces. Needless to say I love it. If I was autocrossing the stiffer springs and bushings would be worthwhile, but on the street, not so much.
Photos here:
http://www.m42club.com/forums/showthread.php?t=6053&highlight=tony92ic
Tony
92 e30 318ic - Why I am here
72 2002tii - Much modified
91 M42 - Am I a hoarder?
///digitalme
« Reply #36 on: June 13, 2010, 12:15:02 AM »
im running, front tokicos for now, back stock shocks
h&r (might be sport oe)
here are some pictures...and tokico shocks arent that bad...ive been running them for 5 months and no problems yet, they have  not blown like they are known to do...
i love my setup not too low not too high since the oil pan gets all the beating i like how it sits now...
« Last Edit: June 13, 2010, 09:01:54 PM by ///digitalme »
supadave
« Reply #37 on: September 19, 2010, 05:53:45 PM »
Blistein sport shocks. Ireland engineering stage 3 springs, and esm 002 16x9 16x7.5
100_1713 by davidkhan82, on Flickr
100_1723 by davidkhan82, on Flickr
100_1726 by davidkhan82, on Flickr
Gerta318is
  • -Receive: 2
« Reply #38 on: September 19, 2010, 06:43:47 PM »
SupaDave ... very nice.  Old Skool for sure.
KenC
« Reply #39 on: September 19, 2010, 07:02:34 PM »
Bilstein Sports
H&R Sports
OMP Alum strut brace
IE 25/22 sway
M3 CABs
IE urethane RSBs and TABs
Solid aluminum diff bushing
20mm H&R spacers
colin86325
  • -Receive: 15
« Reply #40 on: September 19, 2010, 08:18:22 PM »
Bilstein HD dampers
stock 318iS springs
sway bars--E30 M3 rear/E30 cabrio front
E30 M3 control arm bushings
new E30 stock rubber subframe and trailing arm bushings
I wanted to keep stock ground clearance and have a firm but compliant ride because this is my daily driver.
gundy318
« Reply #41 on: September 19, 2010, 11:56:13 PM »
inexpensive option:
kyb shocks/struts, vogtland springs
seadog
« Reply #42 on: September 20, 2010, 10:28:22 AM »
I've installed a set of adjustable height FK coilovers, but only lowered the ride height about 1.5 inches.  I did this to keep tires on it with some sidewall to them.  In my experience with rough roads, this helps quite a bit, I live on a gravel dead end road; great for privacy, but summer equals a car wash every few days.  With this ride height I was able to keep the tire size at 225-45 r17.  I wish I had gone for the adjustable rate shocks but ahh well.
IMO spending money on the suspension dollar for dollar gives the most payback in a fun daily drive, but thats just me.
I need to replace the bushings next time its on a rack, which should be soon.  I plan on replacing the sway bars and installing a strut tower.  Any suggestions on the sway bars, should I go with stock M3 equipment or something aftermarket?
FK coilover suspension
Style 68 wheels with Proxes 4 rubber
Excelon/Powerbass audio
supadave
« Reply #43 on: September 20, 2010, 11:20:51 AM »
Lets see some pics people
fulghumj
« Reply #44 on: January 05, 2011, 07:13:57 PM »
1991 318I. vogtland springs, KYB shocks and struts, 205/50-15 Toyo R888 tires.
It sits pretty low to the ground, but its real nice on the track.
« Last Edit: April 06, 2012, 08:01:43 PM by fulghumj »
