Author Topic: Where's best (cheapest) place to get OE fuel pump  (Read 2988 times)
M42boy
« on: August 10, 2006, 01:16:15 PM »
Hey guys...
I've got to drop the whole #^$^@& rear subframe again.  Since my gas tank is already fubar, I'm going to swap it out with one from the parts car I just bought.  When doing this, I think I might replace the fuel pump.
Is a fuel pump real easy to replace when the tank is in the car (I think there's an access hatch under the rear seat), or is this something I should do at this time while the tank is out and on the ground?  It's coming from a parts car, so I have no idea as to it's condition, but the one in my car still works fine.
And, all that being said...
Where's the best/cheapest place to buy an OEM fuel pump.
No cheapie brands... I want to see "Made in Germany" stamped on it at the very least.  ;)
They seem quite expensive...  like $260!
« Reply #1 on: August 10, 2006, 01:32:05 PM »
Call up Patrick @ BMA parts. They have the pretty competitive prices and you'll be getting the german stuff!
Oh and the fuel pump is cake to take out...took me 2 minutes to take it out of my parts car.
bmaparts.com
Wizard
« Reply #2 on: August 10, 2006, 03:15:48 PM »
Fuel pump is located under passenger side seat, under a cover plate.....You will probably have to unhook the lines anyway when you drop the tank.
M42boy
« Reply #3 on: August 10, 2006, 04:57:15 PM »
Quote from: dude8383
bmaparts.com
If it's that easy, I'll just keep what's in there till it dies, and keep my old one as a backup.  :cool:
Wizard
« Reply #4 on: August 10, 2006, 06:05:40 PM »
I should clarify....It is under the passenger side of the REAR seat....
thumper3ld
  • fathead ***
« Reply #5 on: August 10, 2006, 11:13:47 PM »
I got mine for 180 out the door from parts authority.
Or...
« Reply #6 on: August 11, 2006, 05:39:37 PM »
Take them out and inspect them. Check the socks for crud and clean them. You'll have a pump and a spare and $ in your pocket. Put some stuff in the spare to keep it lubed and prevent corrosion.
Spend the $180 on your girlfriend - that's a high yield investment and way more fun than you can have with a new fuel pump and two spares.
