Author Topic: Dbilas ITB's and m42 buildup on R3v. 318ic, its wicked  (Read 9984 times)
fiftytakedowns
« on: November 12, 2009, 11:29:08 PM »
http://www.r3vlimited.com/board/showthread.php?t=128768
Just thought I'd link a pretty cool car...done right.
deekay
« Reply #1 on: November 13, 2009, 02:04:09 PM »
thx man, glad you like it :)
jgraves
« Reply #2 on: November 13, 2009, 02:34:04 PM »
It like it, but man did he do a lot of upgrades on that BMW.  I would love to put a turbo on my M42, but with it having over 200,000 miles on it I know the turbo would eventually ruin my engine's life span.
fiftytakedowns
« Reply #3 on: November 14, 2009, 01:59:24 AM »
Id love to go the ITB cammed route with an aluminum flywheel, but I am not sure how it would feel.....
deekay
« Reply #4 on: December 12, 2009, 11:48:25 PM »
Quote from: jgraves;81389
everything up until august was done while I was deployed to Iraq- one of the few good things about going overseas is the money that usually goes to cost-of-living can be reallocated elsewhere. getting to check in with Robert @ e30motorwerks and see the progress on the car was a big morale-booster.
I have a turbo manifold from Otis (good & tight), a smallish t3 and about 90% of what I need to get the car turbo'd sitting in storage. one of the things that's great about the m42 is that it saw development and use in the 3-series for quite a while after it's introduction- so if my high-mileage block does give out, then I will just have to cry into a beer and then go find a low-mileage m44 block from a junkyard, because it is my choice to look at it less as an engine failure and more as an opportunity to upgrade ;)
as I've made changes to the car's setup since getting home I have thought quite a bit about how to make sure the turbo setup has the quick-spooling behavior of a rally car- so I am not planning on a light flywheel, but I am considering using a water-air IC rather than the front-mount I already have. if I were to keep the car naturally-aspirated, then reground cams, an aluminum flywheel, and an e36 tranny with a 1:1 5th would be a no-brainer because the ITBs certainly do shift the fat part of the power curve up the rpm range, much the same way hotter cams would.
anyway, yeah, stay tuned. I can't promise progress will happen quickly because I am back to being a college student again, but it will happen.
fiftytakedowns
« Reply #5 on: December 13, 2009, 12:32:45 AM »
thanks for the update!
fiftytakedowns
« Reply #6 on: December 13, 2009, 12:33:21 AM »
Im number one on your list when you decide to get rid of the ITB's
deekay
« Reply #7 on: December 13, 2009, 12:02:19 PM »
sorry to have gotten your hopes up- the ITBs aren't going anywhere, they're just getting forcefed at some point in the future ;)
fiftytakedowns
« Reply #8 on: December 13, 2009, 12:19:59 PM »
hehhe alirght
Bunta
« Reply #9 on: December 13, 2009, 07:10:12 PM »
Cool Build
Theres nothing like ITBs, one of the things that makes an e30 m3 so great.
4pot 4 bodys
deekay
« Reply #10 on: January 31, 2010, 08:07:16 PM »
did a little more work on this thing over the past couple weeks. since i last posted here:
- alpha-N unit turned out to be bad, went back to afm :(
- pulled the convertible trunk anvil and put in thicker rear spring pads to eliminate rubbing
- installed volvo 960/e36 aux fan in front of radiator and eliminated clutch fan
- swapped out 4.10 clutch diff for a 4.10 torsen
- restyled front valance and reiger lip
pics:
more details on e30t/r3v if you're curious, or just ask. :)
Janne
« Reply #11 on: February 06, 2010, 08:19:23 AM »
Can you give us video of your car/motor? I love that itb and i am thinkin to buy one for my car.
Hey-u
« Reply #12 on: February 07, 2010, 12:45:23 AM »
Great build. Definatley gives me some ideas.
deekay
« Reply #13 on: February 07, 2010, 02:45:49 AM »
Quote from: Janne;86799
at&t won't let me upgrade to an iphone 3GS until later in the month, and i haven't decided whether or not to go for it yet (if i do, that's $200 i can't spend on the car). if i do, you'll have video. :)
i can tell you that with the alpha-N unit and a markD chip, the breathing up top was fantastic. wound out to 7000 like it was going to win a prize for it.
my a-N turned out to be faulty (didn't affect open-loop, but daily drivability was awful), and so i had to go back to AFM and after that the power curve fell off a little after 6000... the weight reduction and deleting the fan made up for it, but i still can't help but think how it'd be with some better EMS.
so yeah, if you're going to do the dbilas setup, at the very least get their alpha-N so you can delete the AFM. i would honestly recommend megasquirt, though.
Donkeyshins
« Reply #14 on: February 18, 2010, 02:10:39 AM »
Please make sure you drive this puppy up for the 2010 E30 Picnic.
-D
