Author Topic: My oil cooler project on a SC M44  (Read 17729 times)
LPCapital
« on: November 02, 2009, 12:07:54 PM »
I know this is not really an M42, but the similarities between the two engines are just too many, and I hope others here would benefit from my learnings. Also I decided to post this here in the FI section because of the reason I installed the oil cooler.
A little background: the car is a 1998 Z3 with an M44. I added a Downing Atlanta supercharger kit and got the ECU tuned to run on larger injectors and 3" MAF... I put a lot of work into making the car looks stock, to the point of custom fitting a 6 cylinder's airbox (the stock airbox would not accomodate the 3" MAF). Here's a pix of the final result:
The SC is not intercooled and generate, I beleive, a great deal of heat. I haven't measured the oil temperature, but I know the endurance of the car is affected. So I started looking into adding an oil cooler and an intercooler. I decided to start with the oil cooler...
The first idea was replace the stock oil filter housing with the M42 oil filter housing: the M42 has the same oil filter cap as the 6 cyclinders so I though Irelenad Engineering cap was gonna fit. They managed to fit the cap, but they couldn't find a filter to use so I decided to go a different route.
Through this forum I learned about the Mocal takeoff plate and I bought one from Bat Inc, the Mocal importer here in the US. The problem I'm having now, is that the alternator bracket won't fit once I install the fittings on the plate. I will modify the plate to make it fit.
I took a ton of pix and will post 'em all once I get them organized...
But here's the question now: the oil cooler I'm using is from Ireland Engineering and comes with -8AN ports pre-installed. Based on your guys' experience, are -8AN enough, or -10AN are a must. I would rather use -8AN partially because the whole setup is cheaper (and to be honest I already bought -8AN oil lines and hose ends), but also it will be less bulky? Thanks for any feedback.
Here's a couple of pix of what I got done so far:
Cooler mounted:
Remote oil filter assembly with thermostat sandwitch plate (I actually end up using a top feed oil filter mount because the sid didn't fit):
The oil filter installed near the power steering reservoir with a custom bracket:
« Last Edit: November 04, 2009, 11:17:01 PM by LPCapital »
ethirtysix
« Reply #1 on: November 02, 2009, 06:17:07 PM »
nice pics, nice setup.
i like the effort in the stock look!
more pics of the whole car.
how do you find the suspension on the z3 compared to other bimmers?
david
visionracingdevelopments
« Reply #2 on: November 04, 2009, 07:19:55 AM »
Be interested to see the moded alternator bracket and take off plate. I didn't have an issue with mine as I moved the alternator for my SC brackets.
Fitting an oil cooler will help lower engine temps (I'd personaly fit a bigger rad first) but it wont stop the super charger from bellowing hot air into the engine, with this type of design (charger directly onto the plenum(and especialy a roots pump)), you're a little stuffed for intercooling. The thing to try is maybe water injection but I don't know how good/bad it is?
What sort of power are you producing?
http://www.visionracingdevelopments.co.uk
For sale:
COP converion kits
M42 Silicone coolant hose kits
Braided brake line kits
Performance clutches
Performance brakes
PM me
strypt
« Reply #3 on: November 04, 2009, 10:31:23 AM »
I run AN8 in my oil cooler circuit in my turbo'ed M42. No problems with oil pressure. Have been running it like this for 2 years on both street and track days so it's being used hard.
LPCapital
« Reply #4 on: November 04, 2009, 11:42:16 AM »
Quote from: strypt;80914
This is EXACTLY what I was looking for... Thanks for the comment
Quote from: visionracingdevelopments;80908
I'm not sure I will modify the alternator bracket, I would rather modify the takeoff plate only. But I'll post updates. I'm waiting for BAT Inc (is the importer in the US for Mocal) to receive a couple things I'm returning so they can give me credit to buy a few other things to modify the plate.
And I totally agree with you: an oil cooler will not replace an intercooler, but it will still remove a ton of heat. As for the SC, once the oil cooler project is done, I will work on the intercooler. I will go with an air-water kit and use Laminova cores (probably 2, maybe 3). It will require to modify the plenum and slightly relocate the SC... Not sure when it will materialize, but eventually I'll work on that too.
As for power, I don't have a number off of my car. I'm not interested in dyno or anything like that. However the guy who retuned my ECU said was at around 190 at the wheels.
Quote from: ethirtysix;80832
david
I will post pix as soon as I get everything sorted out. As far as the suspensions goes, a lot of people complain about the "dated" E30 design. I think it's beatufully simple and effective. No complains there. However, as always, the stock setup is too confortable. In mine I replaced all the rear rubbe rwith uretane, added toe & kamber adjustment plate, and went with a mild spring & shocks kit from Racing Dynamics. I'm pleased with the results. Next things I would like to do is stiffen up the front a little (still all rubber) and add camber plates to dial out some understeer I get.
LPCapital
« Reply #5 on: November 04, 2009, 11:53:33 AM »
Here's a couple of other pix.
This is the thermostat sandwitch plate from Jegs which I modified to add the oil temp sender (on the hot side). I added a bras bushing to allow the oil to surround the sender...
These are the oil lines I'm making: -8AN, the lines are Aeroquip FC333 racing hose, while the hose ends are from BAT Inc.
Here's the gauges all wired in:
And here's what I'm dealing with now. Here's the engine without the oil filter housing
And here's the plate. You can notice how close is to the alternator bracket. The purpose of the cork is to measure the clearance I have...
What I'm gonna do, probably, is take a 90 deg fitting, probably -8AN on one side and 1/2" NPT on the other, shorten the 1/2" NPT and probalby shorten the outlet on the plate as well and weld the angle fitting on the plate. This will allow me to minimize the hight and make it fit...
« Last Edit: November 04, 2009, 11:15:48 PM by LPCapital »
Hodge
« Reply #6 on: November 04, 2009, 09:40:27 PM »
This looks like a really nice project, but the only picture working is the first picture in the first post!
1995 E36 318isc
LPCapital
« Reply #7 on: November 04, 2009, 11:17:45 PM »
Quote from: Hodge;80939
Sorry for the inconvenience: I was doing some house cleaning on Photobucket and end up messing up the links... Now they should work
romkasponka
« Reply #8 on: November 05, 2009, 12:47:13 AM »
I am not shure, but I think that your fitting or hose for the these fittings are wrong. I think there should be no gap between fitting and hose.
E30 318is M42
E36 318is M44
1991 E30 M42
« Reply #9 on: November 05, 2009, 03:17:45 AM »
I have had the problem in the past, there are some slight size differences form manufacturer to manufacturer. If you are using Aeroquip hose you should use Aeroquip hose.
romkasponka
« Reply #10 on: November 05, 2009, 04:49:16 AM »
Yes, you should use correct hose with correct fittings. The fittings do not fit all hoses.
E30 318is M42
E36 318is M44
Hodge
« Reply #11 on: November 05, 2009, 07:08:08 AM »
Thanks for fixing the links....project looks great!
1995 E36 318isc
« Reply #12 on: November 05, 2009, 07:59:00 AM »
Ah the M44 bracket is different to the E30 M42 one.
Can you get a banjo fitting in there? Looks like you can squeeze one in.
I used all 1/2" BSP Aeroquip hoses and fittings for mine.
For sale:
COP converion kits
Performance brakes
PM me
LPCapital
« Reply #13 on: November 05, 2009, 11:58:55 AM »
I checked with BAT for the Banjo and the -8AN banjo with the washers and bolt is 1 1/4" tall, way more than what I have... Not to mention that each Banjo set is $50...
As far as the hose ends goes, there is no gap. What you see is a chamfer on the end to be able to slip the steel braid. The hose ends are specifically designed to fit the Aeroquip FC333 hose I'm using
ethirtysix
« Reply #14 on: November 15, 2009, 05:41:40 PM »
quick question on the dasc.  was your kit specific to the year of your car?
i have a 94-95 kit and planning to install it on a m44 z3 (still shopping for the car.)
do you know if i should be anticipating a huge problem?  thx!
David
