I know this is not really an M42, but the similarities between the two engines are just too many, and I hope others here would benefit from my learnings. Also I decided to post this here in the FI section because of the reason I installed the oil cooler.
A little background: the car is a 1998 Z3 with an M44. I added a Downing Atlanta supercharger kit and got the ECU tuned to run on larger injectors and 3" MAF... I put a lot of work into making the car looks stock, to the point of custom fitting a 6 cylinder's airbox (the stock airbox would not accomodate the 3" MAF). Here's a pix of the final result:
The SC is not intercooled and generate, I beleive, a great deal of heat. I haven't measured the oil temperature, but I know the endurance of the car is affected. So I started looking into adding an oil cooler and an intercooler. I decided to start with the oil cooler...
The first idea was replace the stock oil filter housing with the M42 oil filter housing: the M42 has the same oil filter cap as the 6 cyclinders so I though Irelenad Engineering cap was gonna fit. They managed to fit the cap, but they couldn't find a filter to use so I decided to go a different route.
Through this forum I learned about the Mocal takeoff plate and I bought one from Bat Inc, the Mocal importer here in the US. The problem I'm having now, is that the alternator bracket won't fit once I install the fittings on the plate. I will modify the plate to make it fit.
I took a ton of pix and will post 'em all once I get them organized...
But here's the question now: the oil cooler I'm using is from Ireland Engineering and comes with -8AN ports pre-installed. Based on your guys' experience, are -8AN enough, or -10AN are a must. I would rather use -8AN partially because the whole setup is cheaper (and to be honest I already bought -8AN oil lines and hose ends), but also it will be less bulky? Thanks for any feedback.
Here's a couple of pix of what I got done so far:
Cooler mounted:
Remote oil filter assembly with thermostat sandwitch plate (I actually end up using a top feed oil filter mount because the sid didn't fit):
The oil filter installed near the power steering reservoir with a custom bracket:
