Turbo Pics and questions
Author Topic: Turbo Pics and questions  (Read 18399 times)
Euro Nation
    • http://www.euronationmotorsport.com
« Reply #15 on: September 11, 2006, 05:56:07 PM »
Just set up the chain according to the Bentley. Locking the cams and crank in place puts everything where it's supposed to be regardless of the head even being on the block, loosen the cam gear bolts and put the tensioner piston in to take the slack out of the chain, tighten down the bolts, remove the lock tools and you're done. Your cams are timed as factory and your headgasket is thicker.
-Aaron
\'91 318i - Dead and gone
http://www.euronationvw.com
I own VWs... lots of them.
1991 E30 M42
Ideas
« Reply #16 on: November 02, 2006, 07:53:57 PM »
Turbo
« Reply #17 on: November 03, 2006, 04:26:12 PM »
um...
WOW. thats purty...
:eek:
bar73k
« Reply #18 on: November 05, 2006, 06:18:54 AM »
Here is a photo of 8:1 pistons from my m42
Also a photo of my m42 turbo, its currently gettin dynoed and i should be getting it back tomorrow
I will probably do a write up over my uni break holidays, ive been working on this project since december last year.
« Reply #19 on: November 05, 2006, 11:06:03 AM »
well dang, care to share any info? What manifold are you using? Thats the thing holding me back at the moment :(
C.O.P and turbos.
« Reply #20 on: November 05, 2006, 12:10:18 PM »
Turbo setup looks like a perfect contender for the Coil-On-Plug conversion.  No need to sweat the coil pack location or plug wires.
« Reply #21 on: November 05, 2006, 01:11:45 PM »
are those e36 m3 coil on plugs?
« Reply #22 on: November 05, 2006, 01:42:07 PM »
Fits E39 525, 530; all E46; all X5; all E60; E63, E64 645Ci; E65, E66 745, 760; all X3, and MZ3 3.2 with Bremi ignition coils
linky to turner...http://www.turnermotorsport.com/html/detail.asp?PRODUCT_ID=2310
« Reply #23 on: November 05, 2006, 02:15:50 PM »
Quote from: asubimmer;13338
is that link to a used part?
how much do these usually go for?
« Reply #24 on: November 05, 2006, 05:56:59 PM »
Most common application is E46 1998-2001 328i. Also a ton of other models.
$43 for the coil and $5 for the extension from FAP99.com.
http://fap99.com/epcvsoapimc.epc?cookieID=1XJ0MQ9N31XR14LJQ8&drillid=8&subcatid=801079@@Ignition+System&clientid=fap99
And the mount plate from bmwman91.
bar73k
« Reply #25 on: November 07, 2006, 05:45:47 AM »
Quote from: asubimmer;13324
general info:
Pistons:                    8:1 JE Pistons from top-end performance
injectors:                  570cc
turbo:                      T2871R
ignition coils:             Bosch (not sure exactly)
engine management:   Wolf3d Ver4
head gasket:             Cometic
exhaust:                   Custom made manifold, 3 inch dump pipe, high flow  cat, resenator, muffler
intercooler:                From lancer evo (dont know which one)
fuel:                         Walbro intank pump, rising rate pressure reg
Clutch:                      Custom made clutch
also have boost guage inside
soon to be fitted an gredy electronic boost controller
The manifold was custom made for me and cost me about 800-1000 Australian dollars
im happy to answer any questions
« Reply #26 on: November 07, 2006, 09:38:54 AM »
yeah I may shoot some questions your way later, do you have AIM?  mine is asubimmer lol
bar73k
« Reply #27 on: November 07, 2006, 03:53:41 PM »
No i dont have AIM, is that a messaging program?  I have MSN...
« Reply #28 on: November 07, 2006, 03:57:14 PM »
yeah basically like MSN, I'll PM you sometime then
1991 E30 M42
« Reply #29 on: November 17, 2006, 10:56:07 PM »
Where are you getting your pressurized oil from to supply the turbo?
