Author Topic: Turbo Pics and questions  (Read 18425 times)
JungleGus
« Reply #30 on: May 18, 2007, 12:09:57 AM »
well, now im semi seriously thinking about buying this...around 12k NZ$$ which is probably 8.5k US..good buy? makes 180rwkw, so around the 280hp mark (i thought 350 was a little high!)
now has an m20 gearbox (bolt pattern the same, just cut and rotated the bellhousing) after it lunched the m42 one.
totally convinced about 4 cylinders after driving my car (m325i), my mums 318 and a mates M30 335i. so its either this or importing an m3...leaning towards the m3 as they rock, but i could maybe do a partial swap with my car for this.
hmm ideas!
95isTurbo
« Reply #31 on: June 11, 2007, 10:29:26 AM »
Quote from: D. Clay;13342
Most common application is E46 1998-2001 328i. Also a ton of other models.
$43 for the coil and $5 for the extension from FAP99.com.
http://fap99.com/epcvsoapimc.epc?cookieID=1XJ0MQ9N31XR14LJQ8&drillid=8&subcatid=801079@@Ignition+System&clientid=fap99
And the mount plate from bmwman91.
Hey do those coils require a new engine menegement ?
rob_e30
« Reply #32 on: June 11, 2007, 06:21:20 PM »
Quote from: 95isTurbo;27560
No, they plug into the existing coil leads.
Jimmy Lewis
« Reply #33 on: June 23, 2007, 11:47:32 PM »
Does anyone know where bmwman's original sheet metal CAD drawing could be found? I imagine it shouldn't be too hard to make one of the plates if I had a nice template. Thanks guys.
1999 Estoril M3
1991 Brilliantrot 318iS
(for sale)
JungleGus
« Reply #34 on: June 28, 2007, 08:18:40 AM »
am buying this car after i sell mine...anyone else on here have much experience with turbos and thoughts on how they drive? i have my own, but would be interested in others opinions
also, anyone track their M42 turbo?
!RocknE30!
« Reply #35 on: July 10, 2007, 08:06:09 PM »
Quote from: JungleGus;28697
You'll be hard pressed to find many users with M42 turbos, they're few and far between.  I've seen maybe 3 posters on various BMW boards with M42 turbos.  There's a few other pictures of M42 turbo setup floating around, but I don't know who they belong to.
I've looked into turbo'ing my M42, but engine management and a manifold have been the biggest problems.
rob_e30
« Reply #36 on: July 13, 2007, 08:52:28 AM »
I have an M42 turbo that is destined for the track, but it's all the little things that kept it in the garage so far.  It was a much bigger project than I was expecting, and I've done something similar before.  Had I started with a 318 instead of a 325 it would have been easier.  The car runs and there is a You Tube link around here as well as some pics.
Tor Arne Kaasen
« Reply #37 on: July 14, 2007, 02:36:52 PM »
Where are you getting your pressurized oil from to supply the turbo?
BMW E82 120d Coupe and BMW Z3 1,9 m44
rob_e30
« Reply #38 on: July 23, 2007, 12:09:20 AM »
I added a VPD oil cooler and cap which features a port for pressurized oil supply.
ApocolypseAutoEngineering
« Reply #39 on: October 17, 2007, 03:45:56 AM »
What wiring mods do I need to do to get those working properly because its a simple ingenius idea?
E30 FOR LIFE!!!!
vitesse
« Reply #40 on: October 17, 2007, 07:17:22 AM »
none, you just need the coil (the rubber piece that goes onto the coils) and the custom made flat bar that allows the coil packs to be bolted down.
http://www.m42club.com/forums/showthread.php?t=3698
1991 318is: 5 Lug conversion - M brakes - GC track/school 500/650 - (more power here)
JungleGus
« Reply #41 on: December 05, 2007, 01:20:01 AM »
Well, after a long story I ended up buying this car (for a 2nd time). So its all mine! Although, I am in the UK and the car is in NZ...so its gonna be a while. But will have something to look forward to
jpod999
« Reply #42 on: December 05, 2007, 09:58:26 AM »
When you get back.  VIDEOS AND PICS ASAP!!!
e30guydownunder
« Reply #43 on: June 15, 2008, 09:42:44 PM »
Quote from: jpod999;38940
+1 Im keen to see what my cousins across the Tasman were able to come up with :rolleyes:
E30PQ
« Reply #44 on: June 20, 2008, 10:59:57 AM »
Quote from: dude8383;13341
is that link to a used part?
how much do these usually go for?
We sell the COP kits.
We have a new batch of COP kits available.
The kits include top grade hardware (no home improvement store stuff).
$185 w/coils (shipped in the US)
Coils are used but tested prior to shipping. One coil is modified to fit in Cylinder 1.
$80 w/o coils (shipped in the US)
