Ok this is what I have done in relation to oil pressure gauge.
I decided to install an after market oil pressure gauge. However, the VDO sender unit diameter was to big and could not replace the factory pressure switch. I had no choice but to install a T piece. The T piece has 2 threaded provisions on it:
1)VDO sender unit, vertical install
2)BMW pressure switch screws on the end.
I do agree though the factory pressure switch when illuminated, would be too late, the engine is toast. I should have done a little more homework.
