Author Topic: Part number for radiator temp switch plug  (Read 2654 times)
monty23psk
  • -Receive: 17
« on: October 20, 2009, 05:38:19 PM »
One of the clips on my plug that connects to the dual temp switch on the radiator broke off sometime ago and now just want to fix it. I couldnt find it in the ETK and thought I did find it but it is the wrong one. Other option is to find a used one.
thanks
romeomike
« Reply #1 on: October 27, 2009, 02:09:42 PM »
Quote from: monty23psk;80189
thanks
Or do nothing, as the plug has a good friction fit and the headlight cover would likely prevent the plug from backing out.
monty23psk
  • -Receive: 17
« Reply #2 on: October 27, 2009, 06:08:06 PM »
Yeah, but also the water tight plug plastic is cracked an it pieces, so the contacts dont make the best connection in my opinion. I got the part number of the piece itself, but not available. Also I got a good one from the junkyard and ordered a new electrical connector which I hope it is the right one. If it is, will need to get 2 more. Will post pictures if I get it working correctly.
