DISCUSSION
Engine + Driveline
Please help with slight hunting
Topic: Please help with slight hunting (Read 2157 times)
carlos318is
Sr. Member
October 18, 2009, 01:40:23 PM »
I don't use my car any more in the week so last week I took it out last weekend and after a good blast
when I stopped and the car was on tick over there was a slight hunting problem does anyone have any idea where do I start looking :confused:
carlos318is
Sr. Member
October 18, 2009, 01:42:09 PM »
Sorry I forgot to say its a E30 318is
iamcreepingdeath
October 18, 2009, 09:08:56 PM »
what's "on tick over" mean, and by hunting, you mean the idle?
usually a hunting idle means a bad ICV, so take it off and clean it with brake cleaner and see if that helps.
http://www.coloradorallyracing.com
carlos318is
Sr. Member
October 20, 2009, 01:11:56 PM »
Yer sorry I mean on idel the revs are going up to about 1000rpm and down to about 600rpm thanks for the help I will give that a go
RED IS 91
Hero Member
October 20, 2009, 05:41:14 PM »
+1 on the icv ............clean it and then connect 12 volts to it while it's out of the car to see if the little door inside opens and closes.
good luck
The Little Car That Could
214,000 miles
DISCUSSION
Engine + Driveline
