Author Topic: takes long to turnover  (Read 2732 times)
SoupieMelody
« on: October 16, 2009, 08:21:40 PM »
okay i have a 1991 318i m42 engine. When the time was warm the car starts up right away, the battery is good. now it is 36 deg. and when i try to start to the car it would take about 5 seconds before it starts. it behaved as if the battery is low cause it makes a low sound when its turning over and eventually become loud and turns over. even after the car is started and running for a while, switch it off and try to start again, it is the same thing. plz note the car starts everytime.
AcSchnitzer318is
« Reply #1 on: October 16, 2009, 11:20:37 PM »
??? If the battery checks out at 12v+ then I am thinking starter or ignition switch?  Not sure why it would be temperature sensitive though...
SoupieMelody
« Reply #2 on: October 17, 2009, 08:30:51 AM »
yea its weird but idk what the issue is... is there a wy to troubleshoot this?
« Reply #3 on: October 17, 2009, 03:08:29 PM »
Take the battery to a parts store for a load test.  A marginal battery will work fine when it's warm but fail when it's cold.  There is really no way to fully test a battery without high amp loads & volt meter.
Also check for heavy condensation on the battery (that can slowly drain the battery by shorting it to ground) or corrosion on the terminals.
SoupieMelody
« Reply #4 on: October 18, 2009, 08:06:02 AM »
respect Dave, i did just that and apparently with load and stuff autozone said it was the battery so i replaced it and problem solved.
Quote from: DesktopDave;80011
