Author Topic: car wont start  (Read 2571 times)
91 e30m42
car wont start
« on: October 16, 2009, 01:18:16 PM »
hey i just did a complete over haul on my motor and drivetrain rebuilt motor new clutch and clutch accessories new drive axles ne mounts and bushings new hose well u get the idea....but when we try to start it the fuel pump gets no power and also when i take the key out my dash lights and window switch lights stay on also my fuel gauge needle stays at the 3/4 mark and temp needle way off the hot zone what can be the culprit any info will do....could it be a short...mixed wire connect...im somewhat frustrated cause ive been doing this overhaul for 8 months
RED IS 91
car wont start
« Reply #1 on: October 16, 2009, 06:21:04 PM »
Could be a lot of things . Do you have your crank and cam position sensors connected to the right terminals???
You'll have to start doing some testing ....................
fuel
spark
compression
KenC
car wont start
« Reply #2 on: October 16, 2009, 06:28:21 PM »
Make sure all of the sensors are plugged into the harness correctly.
