Author Topic: And so it begins... (another M42 build)  (Read 34751 times)
dj91318is
(another M42 build)
« Reply #15 on: July 28, 2011, 02:56:26 PM »
Looking Good and your doing the work!!!   Wish I could give you a few important suggestions / upgrades you should do while the engine is Torin down   GL
Forgot to say your car is Breathtaking!  ( Sick )
« Last Edit: July 28, 2011, 03:00:59 PM by dj91318is »
bwawuz02
« Reply #16 on: July 28, 2011, 08:54:31 PM »
Quote
Great looking build so far. Do the old and new piston match up height-wise when you install the pin in both to compare them side by side because from the picture they are at different heights? Did you send your timing cover along with your head to be resurfaced?
Cheers,
~Ralph
no, are people doing this? i thought that the whole timing case being separate wouldn't require resurfacing. As for the pistons, I'm using an M44 crank w/M44 pistons, with the rods of both motors being the same length the pistons/pin would have to be different.
Quote
Any input is greatly appreciated ;) thanks for the kind words about my car, just like people though I only post the best pics of her lol.
Got the head back today and installed the MM valve springs/retainers. For $200 i'm not complaining.
« Last Edit: July 28, 2011, 08:58:03 PM by bwawuz02 »
bwawuz02
« Reply #17 on: July 28, 2011, 09:02:54 PM »
I popped the ring gear off my spare M42 flywheel and I'm having rebello swap it with the one on my 528e 13.5lb flywheel. If I don't drop too much money at rebello I might order my cams next week.
I snagged a M44 electric fan from pick n' pull the other day and a non-airbag cruise stalk to go behind my MT2 steering wheel. Now all I need is the actuator cable from an E36 and i'll have all the bits to add cruise.
bwawuz02
« Reply #18 on: August 01, 2011, 11:53:37 AM »
Just snagged the reground cams from hqautosport ;)
dj91318is
bwawuz02 I just subscribed to your build! GL
« Reply #19 on: August 02, 2011, 01:16:04 PM »
bwawuz02 And so it begins... (another M42 build)
I hope I learn something from this for when I tear my  91, 318 Slick apart.
bwawuz02
« Reply #20 on: August 02, 2011, 09:57:23 PM »
matching rear seat is in, semi-permanently
benz-tech
« Reply #21 on: August 03, 2011, 01:18:46 AM »
Hope this all works out for you, based on the first pic I thought you might be building a DUHC motor :D
Nice build. I hope to do something similar as time and funds allow.
bwawuz02
« Reply #22 on: August 04, 2011, 08:05:30 PM »
Quote from: benz-tech;105910
Haha, yeah! I had set the cam trays there to make room on my bench, and when I took the pic I realized that it kinda looks like a face: cam shaft eyes, crank snout nose, and water pump hole mouth...
Hopefully I'll get the rear subframe and 25mm brake MC swapped in saturday.
bwawuz02
« Reply #23 on: August 06, 2011, 07:32:22 PM »
got my cams today, will assemble the rest of the head once I get the block back from rebello. pics to come soon ;)
« Reply #24 on: August 08, 2011, 02:55:39 PM »
What kind of durations did you guy with on the cams? How much were they from hqautosport?
bwawuz02
« Reply #25 on: August 11, 2011, 04:50:56 PM »
dunno, they are used regrinds of stock cams and the hq guys didn't have specs on them. looks like they took a decent amount off the back sides of the lobes (smaller base circle) and increased duration. Don't think I'll have time to have them spec'd. Still waiting for rebello to finish the bottom end. Picked up a full gasket set, just need to order chain rails/tensioner and oil pump relief valve.
bwawuz02
« Reply #26 on: September 13, 2011, 09:37:41 PM »
sorry for the late update, been busy. Just waiting on timing components from blunttech.com
« Last Edit: November 20, 2011, 02:38:04 AM by bwawuz02 »
« Reply #27 on: September 14, 2011, 12:29:58 AM »
What are the advantages of having a single row timing chain?
bwawuz02
« Reply #28 on: September 14, 2011, 01:07:42 PM »
Less rotational mass (~2lbs) = faster revs
Metric Mechanic also says that the single row chains last longer
trackjunkie21
« Reply #29 on: September 28, 2011, 11:46:21 AM »
So when will this be complete, I have a spare m42 sitting at home that I may build up:D
