Author Topic: need some tech help  (Read 2153 times)
abt-e30
need some tech help
« on: October 06, 2009, 09:33:48 PM »
need to know the lobe center of the m42 stock cams.
Thanks for the help.
abt-e30
one other thing.... Engine rebuild ?'s
« Reply #1 on: October 06, 2009, 09:37:15 PM »
what pistons ..stock have a bore size of 85 or 86mm
what cranks swap into the m42 to allow a bigger stroke.....
Im in the process of building a m42 for fun and need some info on the quick.
Ill post pics here soon.
P.s No need to ever port a m42 it flows the same ported or not. Had one flow tested today. Just do a 3 angle grind on the valves and you will be good to go.
abt-e30
need some tech help
« Reply #2 on: October 09, 2009, 03:58:12 PM »
anyone? I found the rank infor m47 320d bmw from germany now need to know the lobe center for the factory cams for my machine guy.....
any help would be apperciated
