Author Topic: M Tech rear spoilers from e28s. Same bolt pattern?  (Read 3177 times)
Ramblin MAn
« on: October 06, 2009, 05:57:47 PM »
Do the e28 rear spoliers have the same bolt spacing as the e30 rear spoliers or are they different. Do any of the bolts match up or is it a completely different pattern all together?
cabin
« Reply #1 on: October 17, 2009, 10:36:07 AM »
I can tell you for sure that the E28 spoilers do not have the same bolt pattern as the e30, I had one on my previous e30.  How different they are, I do not know, since my car came with it already installed.
Sorry I can't be of more help.
monty23psk
  • -Receive: 17
« Reply #2 on: October 19, 2009, 10:21:28 PM »
Only the 3 middle ones will work. You need to remove the 2 outer studs and then use double sided tape. At least that is what I have read and seen.
