Author Topic: oil in cyl #2 HELP!  (Read 2820 times)
flavyphil
oil in cyl #2 HELP!
« on: October 05, 2009, 08:08:31 PM »
hey can someone give me some advice went to change oil and plugs today everything was fine car runs strong no excessive noise i changed thermostat last week. anyway did the oil and filter no surprises started on plugs and when i got to Cly. #2 it was sitting in a pool of oil?! any ideas? thx
B318M42W
oil in cyl #2 HELP!
« Reply #1 on: October 05, 2009, 09:04:12 PM »
check your oil plug gasket from the valve cover.
M90 Blown M42 :cool:
bearsbmw
oil in cyl #2 HELP!
« Reply #2 on: October 05, 2009, 10:28:41 PM »
it's called the valve cover profile gasket and this has happened to me befor and it sucks as it will eventulay cause spark problems if neglected
iamcreepingdeath
oil in cyl #2 HELP!
« Reply #3 on: October 05, 2009, 10:34:51 PM »
yup.  the two guys above are right.  get a new valve cover gasket.  they are cheap and super easy to replace.
flavyphil
oil in cyl #2 HELP!
« Reply #4 on: October 05, 2009, 11:01:08 PM »
you guys rock! how confident would you say you are that this is the problem, and is there a way to check without taking the cover off?
quinn11m20
oil in cyl #2 HELP!
« Reply #5 on: October 06, 2009, 03:21:00 PM »
Hey just to let you know that when you do replace them, make sure you tighten the valve cover bolts correctly. I did and had to remove and retighten a few times over a period of three weeks. I still get a little oil down in the plug well.
1991 E30 M42
oil in cyl #2 HELP!
« Reply #6 on: October 06, 2009, 09:16:51 PM »
buy some helicoils while your at it to fix the striped threads
flavyphil
oil in cyl #2 HELP!
« Reply #7 on: October 06, 2009, 09:46:49 PM »
nice thanks for the tips! Im going to do a write up on it just cuz it might be cool to have it around
