Author Topic: rev limiter  (Read 5643 times)
pappouszx6r
rev limiter
« on: October 05, 2009, 08:45:55 AM »
Hi to everyone!!!
I am new to the club and i want your advice.
At what rpm can a normal m42 (with stock valve springs, valves and retainers) can run without any problems?
bearsbmw
rev limiter
« Reply #1 on: October 05, 2009, 11:14:03 AM »
NA 6800rpm and you start loosing power
FI  7000rpm is power limit
this is based on stock internals
pappouszx6r
rev limiter
« Reply #2 on: October 05, 2009, 11:39:01 AM »
I am planning to replace the chip on the ecu so i want to know where is safer to set the rev limiter.
Hope that the chip will work so i won't run out of power at high rpm.
Warsteiner
  • -Receive: 21
rev limiter
« Reply #3 on: October 05, 2009, 01:22:28 PM »
FYI: There is an Instructor that I run with and he has a stock M42 internals with DASC and revs the thing to 7500rpm all day long and has been for years!
pappouszx6r
rev limiter
« Reply #4 on: October 05, 2009, 01:44:11 PM »
That sounds good! Anyone else who has tried it?
bearsbmw
rev limiter
« Reply #5 on: October 05, 2009, 02:45:18 PM »
Quote from: Warsteiner;79436
sure you can rev to 7500-8000 all day long but that won't give you anymore power when the valves are floating... After 7000rpm its the momentum of the crank and the high power you made in the low rpms
It costs big bucks and major valve train upgrades to make power in the high rpms
This only applys for the M42 and the research I have done... I know nothing about any other bmw engine
« Last Edit: October 05, 2009, 10:18:39 PM by bearsbmw »
fscalise
rev limiter
« Reply #6 on: October 06, 2009, 12:40:40 PM »
Hey guys what is the best rear end for my 1991 E30 with M42 and stock internals, chipped with ram air. I want more low to mid power.
bearsbmw
rev limiter
« Reply #7 on: October 06, 2009, 01:18:22 PM »
If your not worryed about fuel economy I would hit up the 4:10 I have a 3:45 LSD in my turbo and like it
xwill112x
rev limiter
« Reply #8 on: October 07, 2009, 04:27:50 PM »
Quote from: fscalise;79501
4:45
i think you can get the diff ring set out of a 318 vert?
Ich liebe meinen E30
bwawuz02
rev limiter
« Reply #9 on: October 07, 2009, 06:04:37 PM »
Quote from: xwill112x;79564
4:45
or an automatic E36 318
deekay
rev limiter
« Reply #10 on: October 07, 2009, 06:12:10 PM »
318 vert 5spd has 4.27... at least, mine did until i swapped in an M3 diff.
318 vert auto is probably a pretty damned rare car, unfortunately.
pappouszx6r
rev limiter
« Reply #11 on: October 10, 2009, 08:09:12 AM »
Quote from: bearsbmw;79448
So you think that with a high flow intake and a proper managment you can't get power after 7000+ rpm?
