Author Topic: fluids type and capacities question  (Read 1986 times)
Ramblin MAn
« on: September 29, 2009, 04:47:43 PM »
5 speed trans in a 91 318 IS. What is called for exactly, and how much does it hold?
Also, the rear end. Same car, same question.
And I did search, but for some reason it just doesn't work well for me. If I put in atf I get no hits at all even though I see it all over.
I've read several posts but I get conflicting info. The owners manual one of you were kind enough to send me is for the 325 which makes it een more confusing.
« Reply #1 on: September 29, 2009, 05:12:16 PM »
Similar topic from the past... LINK
Ramblin MAn
« Reply #2 on: September 29, 2009, 05:58:36 PM »
Thanks you sir. Exactly what I was looking for.
Ramblin MAn
« Reply #3 on: October 03, 2009, 02:02:41 PM »
Well, Changed the fluids in the tranny and the rear end, but contrary to what I read in all of the threads I could find, my diff only took one quart. The tag read 4.10 90 and it is posi. What sucks is it took exactly one quart without spilling which means I opened the second 9 dollar quart of fluid for no reason. I expected it to take two but the first sqeaze of the second quart just ran out of the filler hole.
