Author Topic: Bolts not torqueing down  (Read 2319 times)
seph429
« on: September 23, 2009, 02:23:21 PM »
Okay i had to replace the lower and upper oil pans, well in the process of putting the upper one back on, the bolts inside the pan wouldnt torque again. (the ones covered up by the lower oil pan)
as soon as it started to feel even slightly tight, it would just slip.
I left it there for now, i dont want to totally strip the bolts/threads.
Anyone have any suggestions on how to handle this so i shouldnt have to worry about them falling out? and any clue why it suddenly wouldnt torque down anymore?
« Reply #1 on: September 23, 2009, 03:55:55 PM »
IN the future, use a torque wrench and specs. The threads are trashed.
1991 E30 M42
« Reply #2 on: September 23, 2009, 04:35:03 PM »
time to go get some timeserts or helicoils
AcSchnitzer318is
« Reply #3 on: September 23, 2009, 10:34:19 PM »
Yep... whenever dealing with aluminum it is a good idea to use no larger than a 3/8" drive ratchet and hold it in the middle.  That way it is almost impossible to over torque them.  Luckily all my upper pan bolts were fine, but the PO stripped 2 of the lower pan bolts, and 2 of the cam cover bolts.  Also luckily, I do not have any leaks from those points, but it still sucks.
The above is if you do not have a torque wrench.  I don't so I use the above as a rule.  If you have one... use it.
