DISCUSSION
Engine + Driveline
Water leak!
Topic: Water leak! (Read 2007 times)
Sean_318is
Water leak!
September 21, 2009, 09:40:47 AM »
Hi guys, I've found water leaking onto my exhaust from the rear of the engine...
Any common things there? Thanks
1994 BMW 318is Coupe
iamcreepingdeath
Water leak!
September 22, 2009, 07:17:17 PM »
from the rear of the engine?? nothing common there... check the coolant drain bolt in the block that is under the exhaust header right near the transmission bellhousing.
http://www.coloradorallyracing.com
DISCUSSION
Engine + Driveline
Water leak!
