Author Topic: COP Brackets: Your Preferences?  (Read 81160 times)
TheNeek
« Reply #150 on: February 14, 2008, 03:09:43 PM »
bmwman91 and others:
I made an english print version of the COP plate, for us folks that don't have spiffy digital read outs on our mills that work in the metric system.  I'm the machine shop manager at work and all I get are dials that read in thous.  If anyone is interested in what the measurements are in english units, I have it on PDF.  It's in Pro-E wildfire 3.0 if people can open the file, I'll send it.  Also I can convert to .dwg or .dxf for those that are interested.  Here's a Jpg:
« Last Edit: February 14, 2008, 03:16:25 PM by TheNeek »
haledj
« Reply #151 on: February 14, 2008, 03:13:10 PM »
Quote from: TheNeek;42788
A few of the holes there are in different places than I use most notably, the one in the upper right corner, and the mounting holes and the big holes are not inline.
TheNeek
« Reply #152 on: February 14, 2008, 03:16:04 PM »
Quote from: haledj;42790
Agreed... Why is that one hole on cylinder one all out of place?  I was toggling back and forth between the Metric PDF print and my model, guess I Goofed.
Better?
« Last Edit: February 14, 2008, 03:35:46 PM by TheNeek »
haledj
« Reply #153 on: February 14, 2008, 03:44:38 PM »
Quote from: TheNeek;42791
Better?
It would hit the valve cover on the end.
Is this file different?  I should have said that the mounting holes and the should not be inline.
TheNeek
« Reply #154 on: February 14, 2008, 03:47:57 PM »
Quote from: haledj;42793
I changed the file on photobucket... so your qouted picture three posts up is actually referring to the new file as well.  Tricky :D
Is the cylinder one coil pack different?  I'm looking at the metric print (which is correct) and the other hole for that coil pack, is in the same relative location as the other 3 in that row (in relation to the spark plug holes).  How can this be?
Just looked at the pics in the GB thread.  So there are two sets of holes for each coil... and you lop off the ear in that particular corner.  Interesting.
« Last Edit: February 14, 2008, 03:53:17 PM by TheNeek »
haledj
« Reply #155 on: February 14, 2008, 04:02:29 PM »
yep that is the way we do it.  It works really well.  :)
TheNeek
« Reply #156 on: February 14, 2008, 04:20:25 PM »
Quote from: haledj;42795
Is there a coil that doesn't have the two holes?  Instead has just the one that is closest to the center axis.  I think having one coil be different would bug me.
haledj
« Reply #157 on: February 14, 2008, 04:54:22 PM »
No, you have to cut/grind off the outer part
Jak318
« Reply #158 on: February 14, 2008, 08:04:25 PM »
Quote from: TheNeek;42796
Its crammed in the corner anyway. You won't even notice.
pwforprez
« Reply #159 on: February 16, 2008, 02:49:07 AM »
coils are on the way. this looks like it should be a fun project
TheNeek
« Reply #160 on: February 18, 2008, 04:48:27 PM »
Quote from: pwforprez;42871
who was your coil source?
pwforprez
« Reply #161 on: February 19, 2008, 10:46:51 PM »
ebay. they should be here in a couple days
pwforprez
« Reply #162 on: February 22, 2008, 04:29:16 PM »
coils are in my possession
250k318is
« Reply #163 on: February 24, 2008, 08:06:07 PM »
i just made one of thease brackes and go the coils from flea bay i work in a shop so accsess to the machines to make them a easy:o
n2motorsports
« Reply #164 on: March 18, 2008, 06:51:38 PM »
Okay, still a bit confused on the ignition coils.
in the pdf instruction it says to use: 12-13-1-748-018
pictures above are clearly:              12-13-1-748-017
can either one be used?
