Author Topic: ingnition wiring for push button start.  (Read 2435 times)
miller3339
« on: September 17, 2009, 11:42:17 AM »
i'm looking for information on the wiring for my ignition so that I can use a momentary switch/button to start the car. i need to know what wires to put a switch to for accessories and running and what wires to connect for the start. From what I can see of the wiring diagram. the Red should go through a on off switch to Green for accessories and running.  The Red  should go through a momentary switch to the Black/yellow wire for start.
for those curious I'm taking out the steering wheel lock and the ignition tumbler is toast.  since this will be a rally/cross/autoX sunday thrashing car. i'm not to concerned about having a key to start.
thanks for you help
Miller
this is for my 1991 318is
