Author Topic: Top speed for the E30 318is?  (Read 9566 times)
fabe
« on: September 14, 2009, 02:15:59 AM »
I know the M42 isn't built for top speed runs, but just curious if a close-to-stock M42 can go beyond the standard top speed
E30 318is : 127mph (~203.2kph)
E36 318is : 132mph (~211.2kph).
* figures obtained from Brendan Purcell's website: http://www.esatclear.ie/~bpurcell/318istechinfo.html
Tried a high speed run some time last week. My e30 with the E36M42 and Getrag 250 (3.15 rear diff), managed to top out at 215kph(as shown on GPS), speedometer indicated ~225kph. The car won't go any faster after holding that speed for more than 1 minute. Rev was about 6,200rpm
quinn11m20
« Reply #1 on: September 14, 2009, 01:36:55 PM »
I have had mine up to 152. That was with a performance chip and K&N Filter. Plus a stock clutch. I used a Garmin GPS as a speed reference. I did it on a flat Highway out here in Florida.
318isfolife
« Reply #2 on: September 14, 2009, 02:12:59 PM »
k and n drop filter, dynomax hi-flow muffler (stock piping), turner chip. I have seen 135 and i still had a bit to go in 5th. the high ways over where im at arent really flat either. im sure on a flat road that is uber-long you could easily get this car to 145-7 ish.
fabe
« Reply #3 on: September 14, 2009, 10:06:43 PM »
Quote from: quinn11m20;78429
What's your final drive ratio and what engine speed was it at 152mph?
roundel318
« Reply #4 on: September 15, 2009, 04:31:25 PM »
BMW spedo's are famously optimistic.
I have seen fuel cutoff in 5th with a shown speed of ~140mph @ 6550rpm.
I doubt it was doing any better than 135mph, I would guess around 131, 132mph.
This was on a stock car that had nothing done to it.
fabe
« Reply #5 on: September 16, 2009, 12:17:51 AM »
Quote from: roundel318;78475
Which is why the mention of GPS-indicated speed... ;)
The difference between the GPS and speedo is about 8kph... ~5mph..
roundel318
« Reply #6 on: September 16, 2009, 03:25:31 PM »
Nice, I have problems reading :)
quinn11m20
« Reply #7 on: September 16, 2009, 09:32:20 PM »
My tach was at 7000k. the speedo was way past the 140 mph mark, and I will add it was in the 70's (70 Deg F). I don't know if that helped any. I redlined every gear, when I got to 5th I just put my foot down as hard as I can get. And actually, I had recently replaced the speedo gears and took the car to get calibrated. I was 3 miles over. My Garmin was new and was put to the test with a buddies car. So plus or minus 3 miles an hour, She was about 152.
fabe
« Reply #8 on: September 16, 2009, 10:06:36 PM »
Quote from: quinn11m20;78553
I have guessed that the car would need 7,000rpm to go beyond 145mph.. Are you running stock 4.10 final drive ratio on the E30?
« Reply #9 on: September 16, 2009, 10:44:38 PM »
kenika65
« Reply #10 on: September 17, 2009, 01:21:57 PM »
Been at 135 with 3.93LSD on the speedo...
quinn11m20
« Reply #11 on: September 17, 2009, 03:31:11 PM »
Well the tach was more than 7k, and yes it was the stock diff.
Birdman16
« Reply #12 on: September 18, 2009, 12:14:27 AM »
Around 140 the speedo said... I was drafting a 550i sport but I think the speedo was a bit off... Friggin scary but sweet!
From The Gumball Rally
Family Rides:
Dad: 03 325i (E46)
quinn11m20
« Reply #13 on: September 18, 2009, 04:39:08 PM »
You ain't lying about friggin scary. My car was floating all over the road.
xwill112x
« Reply #14 on: September 18, 2009, 04:46:08 PM »
ive touched on 140 before..
Ich liebe meinen E30
